arkietumbler
Member since February 2016
Post by arkietumbler on Mar 3, 2016 17:15:11 GMT -5
While exploring some property we purchased, I hiked a small limestone bluff and found a pie plate chunk of crinoids!
My question is it is possible to break up this chuck and tumble to polish?
Post by jakesrocks on Mar 3, 2016 18:08:15 GMT -5
Crinoids in limestone will be very soft. You could attempt to do them in a vibratory tumbler, starting with something like 300 grit & checking progress every day. Why not save that pie plate sized death plate as a specimen ? Surely there are many crinoid pieces which have weathered out of the limestone and could be easily picked up.
Mark K
Member since April 2012
Post by Mark K on Mar 3, 2016 19:06:49 GMT -5
Post a pic. We like pics.
Post by Fossilman on Mar 3, 2016 21:46:01 GMT -5
I usually won't tumble fossils.......Some are very fragile and will break apart............
arkietumbler
Post by arkietumbler on Mar 3, 2016 22:57:18 GMT -5
As I hiked up the side of the bluff trying to avoid thorns and vines, I looked down and my eye caught a tiny circle like a doughnut. This is the top: I flipped the rock over and this is what I found!
Post by jakesrocks on Mar 3, 2016 23:22:41 GMT -5
Very nice death plate. If you buy a piece of 1/8" hardware cloth & build a wooden frame for it, you should be able to screen out bunches of loose crinoid pieces from the soil downhill from where you found that piece. When I was a kid in N.E. Ohio, we used to pick up pockets full in the fields around us.
arkietumbler
Post by arkietumbler on Mar 4, 2016 0:07:38 GMT -5
Very nice death plate. If you buy a piece of 1/8" hardware cloth & build a wooden frame for it, you should be able to screen out bunches of loose crinoid pieces from the soil downhill from where you found that piece. When I was a kid in N.E. Ohio, we used to pick up pockets full in the fields around us. Thanks jakesrocks! I will have to do that! The land we bought is 11 acres total and about 3 of those acres are limestone bluffs! I'm sure there's going to be lots to explore!
Post by jakesrocks on Mar 4, 2016 0:29:01 GMT -5
If you happen upon any trilobites, keep me in mind. I collect them.
Since moving to South Dakota, while screening rocks out of new flower beds, I've found 4 very crudely made early arrow heads, and a couple small pieces of coral which were probably dropped here by the last ice age.
Don
Post by talkingstones on Mar 4, 2016 7:09:35 GMT -5
We just moved to Indiana in the Ohio River Bluffs near Cincinati. Are you in the area jake? I'm finding similar stuff here?
Post by Jugglerguy on Mar 4, 2016 9:42:37 GMT -5
I have found lots of limestone crinoid stems in my area. I've never tried to tumble them. I think it would ruin them if you made them smooth. I have successfully tumbled Petoskey stones though. They're also limestone, so crinoids might be able to be tumbled using the same method. I used corn cob media in a vibratory tumbler. Read about it here. Since that post, I have tried corn cob animal bedding that I bought at Walmart and had good luck with it. I'd try that before ordering some made specifically for tumbling. Let us know how they turn out (or don't turn out).
Post by Fossilman on Mar 4, 2016 9:50:56 GMT -5
Post by jakesrocks on Mar 4, 2016 11:55:56 GMT -5
We just moved to Indiana in the Ohio River Bluffs near Cincinati. Are you in the area jake? I'm finding similar stuff here? LOL, My parents moved me away from Ohio way back in 1948. The area where I was a young boy is now covered in asphalt & shopping malls.
arkietumbler
Post by arkietumbler on Mar 4, 2016 12:38:45 GMT -5
I'll forego the destruction the death plate and go back and look for some bits and pieces at the base of the bluff. There's so much to explore! There are plenty of arrow heads in the area as well.
Here's our little chunk of heaven we purchased. We plan on building out here for retirement. It's located about 8 miles outside of the town. The large tree dense area in the center is the bluff which is about 30-40 feet higher than the rest of the surrounding pasture land. I found the loosened Crinoid plate at the base of the bluff.
