astrobouncer
Member since January 2016
Post by astrobouncer on Mar 21, 2016 17:41:27 GMT -5
I got into rock tumbling on 1/19/16 of this year with a lot o tumbler vibratory tumbler. Then on 2/1/16 I bought a harbour freight chicago tools 6 pound rotary tumbler. My power bill for feb was normal which is around 240$. But then this month it was double that, over 480$. Could this possibly from the tumblers and how do I tell?
Post by Drummond Island Rocks on Mar 21, 2016 17:56:15 GMT -5
Post by Drummond Island Rocks on Mar 21, 2016 17:59:29 GMT -5
I run my lot-o and 40 pounds of rock in rotaries 24-7 all year for about $20-30 per month in electricity.
Intheswamp
Member since September 2015
Post by Intheswamp on Mar 21, 2016 18:30:28 GMT -5
Something's goofy (or donald) with your meter reading. Do you have your meter manually read or is the meter reading electronically transmitted to the electric company's office? If manually they could have been "estimating" your usage for a few months and billing less than what you were actually using and it caught up or they could have simply misread the meter. But, no, it shouldn't double your power bill. Or, you could have a very badly malfunctioning electrical device...heating/cooling, water heater, etc.,....
Post by captbob on Mar 21, 2016 18:31:44 GMT -5
bills
Member since March 2016
Post by bills on Mar 22, 2016 0:34:00 GMT -5
That is just crazy. My 4# vibe tumbler draws .6 amp x 120volts = 72 watts x 24 hrs. = 1.73 kwh. x $ .22 per kwh. = $ .39 x 30 days = $ 11.07. $.22 per kwh. is the high rate base rate here in so.ca. is more like $ .10-.14 per kwh. Oh BTW great forum glad to be a part of it , just running my first batch and after following the guides here it is progressing well. I am a retired electrician and a desert rat.
hopes this helps regards bill
Post by jamesp on Mar 22, 2016 7:24:37 GMT -5
1/3 HP running 3 barrels at 20 pounds each is about $30/month in Georgia.
Post by Fossilman on Mar 22, 2016 9:26:15 GMT -5
Nope,it doesn't sound right at all...I run two tumblers all winter long,plus my saw......Not much of a change with them running...
Intheswamp
Post by Intheswamp on Mar 22, 2016 10:37:18 GMT -5
That is just crazy. My 4# vibe tumbler draws .6 amp x 120volts = 72 watts x 24 hrs. = 1.73 kwh. x $ .22 per kwh. = $ .39 x 30 days = $ 11.07. $.22 per kwh. is the high rate base rate here in so.ca. is more like $ .10-.14 per kwh. Oh BTW great forum glad to be a part of it , just running my first batch and after following the guides here it is progressing well. I am a retired electrician and a desert rat. hopes this helps regards bill Welcome to the forum, Bill. Sounds like you're well on your way to tumbling. And you're calculations are reasonable and logical.
peachfront
Member since August 2010
Post by peachfront on Mar 22, 2016 12:27:21 GMT -5
Call in a complaint and insist they read the meter again. They read it wrong. Either that, or else they haven't been bothering to read it for months, and now they finally had to get caught up with what you actually owe. I've had both of these things happen. It isn't caused by the tumbler. It's caused by sloppy meter readers.
