showet
Member since June 2015
Post by showet on Apr 21, 2016 17:12:11 GMT -5
I am basically a novice. I have been learning by trial and error for the last year or so. I want to slab and polish the rock below that I bought at a rock shop but I know that for some rocks there is a best orientation to cut a rock. I don't want to spoil this rock through ignorance. Does anyone have an opinion of if it makes any difference which direction I cut the rock? If I look at the second view (what I call the side view) I can see some poorly defined layers. I could cut across the broad side (Top) or try and slab in the direction of the layers even though they are not well defined. Top side
Post by Deleted on Apr 21, 2016 17:31:59 GMT -5
That doesnt seem to have a special orientation. What is the material?
Post by orrum on Apr 21, 2016 17:32:39 GMT -5
No idea but a very nice rock!
Post by vegasjames on Apr 21, 2016 17:45:29 GMT -5
Looks like rough labradorite.
Post by Deleted on Apr 21, 2016 17:50:18 GMT -5
Looks like rough labradorite. If that is the case, my answer prior, must be ignored. Lab is very difficult to orient, and every single fut may have a different angle.
showet
Post by showet on Apr 21, 2016 18:50:13 GMT -5
Here is another couple of photos taken of the other side to show the color better. This was done inside with a flash. I thought this was sodalite but it does not have the normal white lines (just some spots) and it does not fluoresce, however I don't have a full spectrum light to really test it. I would not have thought of Labradorite because I don't see any real sheen from any angle.
Post by Fossilman on Apr 21, 2016 19:07:57 GMT -5
If your slabbing it,I would start on the thick end and work in...............Get more slabs per rough..............
Dr DG
Gone Fishing
Member since April 2005
Post by Dr DG on Apr 21, 2016 19:34:45 GMT -5
Looks like Africa sodalite
Post by Drummond Island Rocks on Apr 21, 2016 19:57:41 GMT -5
I do not see any reason for special orientation on that one. For rocks like that I always choose the best/safest spot to clamp the rock and cut it according to that. Cut slices till you run out of cross feed then glue to a board and cut the rest.
Post by broseph82 on Apr 21, 2016 23:49:19 GMT -5
Looks like rough labradorite. Def NOT labradorite. Cutting is trial and error sometimes. Nothing to it but to do it
showet
Post by showet on Apr 22, 2016 8:10:54 GMT -5
Thanks all. I just did not want to ruin a good piece or fail to get any color out of it.
Post by Deleted on Apr 22, 2016 10:38:10 GMT -5
Thanks all. I just did not want to ruin a good piece or fail to get any color out of it. If there is color, you should get it from any angle. At least that is the read I am getting from our friends. That doesnt promise you will get any color at all. Surface color does not guarantee internal color.
Post by deb193redux on Apr 22, 2016 15:18:40 GMT -5
I suspect blue adventurine quartz. I would just cut along or across bands to get pleasing patterns. Adventurine does not have a right direction.
Mark K
Member since April 2012
Post by Mark K on Apr 22, 2016 20:35:13 GMT -5
I seem to remember seeing something like this called Denim agate or jasper. Problem is that GIS brings up dick.
showet
Post by showet on Apr 23, 2016 12:06:01 GMT -5
FYI, I cut it and so here is a quick photo of a few of the slabs.
Post by orrum on Apr 23, 2016 12:29:36 GMT -5
They Look good! My luv in life is to cut em, whack em, slice em, look I side them rocks!!!! LOL
Post by washingtonrocks on Apr 24, 2016 8:30:30 GMT -5
Azurite in quartz? Whatever it is, I like it. I usually just shave all of the sides of my rough to find the direction with the best color/most appealing pattern and go from there. Don't think you can really go wrong with that stone!
