sifu
Member since September 2010
Post by sifu on Apr 22, 2016 9:54:33 GMT -5
Is anyone running oil cooled saws indoors, especially larger slab saws? I'm in the process of acquiring my first saws and would like to set them up in my unfinished basement. I plan to use mineral oil for coolant. Do I need to seal off the rock shop area from the rest of the basement (where the furnace resides, etc.)?
I am planning on making some ventilation improvements, but I know most people use oil cooled saws out of doors, or semi out of doors. Thoughts?
Post by Fossilman on Apr 22, 2016 10:03:03 GMT -5
Two of my Uncles had saws in their basements,if I remember right the only thing they did was run fans,that would steer the mists and etc towards the door,instead of the furnace areas.........
Post by orrum on Apr 22, 2016 11:10:13 GMT -5
Mark/Marinedad ran his saws in the basement. Put Bardahls no smoke in the oil, I use about a cup in my 16 inch saw. It cuts back the mist bigtime!
Post by DirtCleaner on Apr 23, 2016 12:52:52 GMT -5
No problems with my 12" Lortone in the basement. I do use Bardahl No Smoke along with Crystex (White Mineral Oil) If you have any problems with mist let the hood stay shut for a while and then add more Bardahl. it can be had at many local auto supply stores.
Post by Peruano on Apr 23, 2016 15:27:52 GMT -5
If you have major mist problems with mineral oil you: 1. are running way too much oil depth on your blade and hurling it everywhere or 2. You forgot to put the top down on your slab saw. I run my 12" slab saw with a homemade top for several hours everyday in my workshop (concrete floor peg board wall covering) and have no evident mist problems (yes I have a bit of oil film on the saw itself but nothing a simple cloth wipe off doesn't cure. The only advantage I might have over others is the dry dusty climate of New Mexico. I clean up drips on the floor with oil dri from Walmart and make many round trips from shop to house across a beige carpet, and believe me, if I was tracking oil from the shop on my shoes my wife would have noticed - no problem there so I have to say that mist is not much of an issue. I do suggest a top that does not just contact but rather overlaps] the saw tank (ovesrlap on inside). . . . So , I would not hesitate to put a saw in a basement, but with the proviso that you solve oild problems as they appear (if and when they appear). Enjoy the ride. Tom
Post by DirtCleaner on Apr 24, 2016 20:42:42 GMT -5
Here is a hint for oil spray. When you think you have it licked, take on old irreplaceable family photograph and set it a few feet away from the saw. If you don't get it oily then you are good.
