Post by ogcookie3rocks on May 18, 2016 20:44:10 GMT -5
Can graphite powder be used as a polish in a vibe? There is a 1 lb jar on Ebay (Microfyne brand) that is listed under lapidary grit for tumbling, but no real description. I'm not sure that the seller even knows. Thanks!
Post by Deleted on May 18, 2016 23:28:10 GMT -5
Graphite is a mohs 1-2. It will cut anything softer.
If you plan to polish talc or other very stuff stuff it could work.
What is it that you are polishing?
Post by vegasjames on May 19, 2016 0:21:25 GMT -5
Even if it could it would be a major mess.
Post by ogcookie3rocks on May 19, 2016 12:44:20 GMT -5
I just didnt know anything about it. Thanks
Post by vegasjames on May 19, 2016 15:17:02 GMT -5
I just didnt know anything about it. Thanks I have a lo to graphite (powder, flakes, solid) for a project I am working on. The powder gets on to everything and is hard to get off. And as Scott mentioned it is very soft. Not all that cheap either. Better going with aluminum oxide.
metalsmith
Post by metalsmith on May 6, 2017 0:03:57 GMT -5
Even silver is Moh's 2.5, but it might have a use polishing that ... once you've washed off all the grey. Think soft (art) pencil lead and you're about there.
I have an experiment to run with another soft material after making reasonable observations that it seems to polish silver very well - hair!
Post by 1dave on May 6, 2017 7:38:13 GMT -5
The old stand by's - cerium and tin oxide.
Post by jamesp on May 6, 2017 7:42:09 GMT -5
Graphite is one of the finest. And messiest. Wicked lubricants on earth. A dry lubricant that has the qualities of a wet lubricant. Used as lubricant when forging steel as it takes super high pressure and super high temperatures. The only way to get it off steel is to let the steel rust and undermine it off. Graphite electrodes carrying serious electrical current to melt steel Typical steel mill graphite electrodes
