beginner
Member since February 2013
Post by beginner on May 21, 2016 11:10:02 GMT -5
Hi---I'm new here. I just got my first saw (QEP 3/4 HP Wet Tile Saw with 7 in. Diamond Blade) from HD. I would like to get a sturdy rolling cart (with good wheel breaks, of course!), in order to roll my saw from inside (where it's being stored) to outside where I could use it on the cart as a base. Does anyone have any ideas for a cart like this? I have been googling, but thought maybe someone else has done this and would have something to recommend. Thank you!
ol3m3
Member since September 2006
Post by ol3m3 on May 21, 2016 11:20:02 GMT -5
Try some place like harbor supply, or northern tool, both have rolling carts, you will probably have to get a pc of plywood to put on top as most of the carts have a recessed tray.
Post by manofglass on May 21, 2016 11:33:46 GMT -5
Post by Jugglerguy on May 21, 2016 11:49:50 GMT -5
i built my own cart. It wasn't difficult. With a tile saw, you'll be spewing water, so you will need to think about waterproofing. I used locking wheels from Home Depot. Here's mine: I used two by fours, scrap particle board, and luan plywood for the sides. I built shelves for more rock storage.
beginner
Post by beginner on May 21, 2016 11:58:55 GMT -5
Thank you all for the suggestions and welcome. Rob--what a beautiful job you did on your cart--and so functional, with storage, too. I don't have the skills or tools to do something like that, unfortunately. I will have to visit some stores. Online it is hard to tell how sturdy things are. And I don't really want to spend more on a cart than I spent on a saw! ?
NDK
Post by NDK on May 21, 2016 12:56:23 GMT -5
Check thrift stores or if you have a ReStore nearby try there too.
I was at a restore after picking up my daughter from college & they had a perfect cart for my trim saw for $35. Of course I was 150 miles from home with my truck bulging at the seams with dorm room stuff...
Post by jakesrocks on May 21, 2016 13:00:07 GMT -5
Try checking for used equipment stands on ebay. I bought one of these complete with the wheels for less than what this seller is asking. They're very heavy duty, and the height is adjustable on the old ones. www.ebay.com/itm/322114684898?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AITThese are made with threaded holes in the bottoms of the legs that the wheels screw into. Any locking wheels with 5/16" threaded mount will work. The stand legs & other parts are made of 14 gage steel, unlike the 18 gage steel being used in the new ones. A storage shelf can be added to the bottom braces very easily.
beginner
Post by beginner on May 21, 2016 14:59:21 GMT -5
Nate--we're picking up my son and his girlfriend from college next week, so I just may look around there! Thanks! Don--thanks for the Craftsman stand info--I wouldn't have known you could easily put wheels on those!
Post by jakesrocks on May 21, 2016 15:46:45 GMT -5
Post by Fossilman on May 26, 2016 17:07:07 GMT -5
Built my own cart too-easy to do and you build it the way you want it built!
Post by Pat on May 26, 2016 17:19:17 GMT -5
I think I have the same saw ( used). I put it on a used cart with wheels. I'll go check it out soon. Must use it outside.
