salpal48
Member since March 2015
Post by salpal48 on Jun 8, 2016 8:21:27 GMT -5
. I recently Purchase 2 Older rotary tumble Machines . I am looking for 2 steel drums 6 LB capacity these must have the Internal rubber liners , and lids. . These are the older standard type for star diamond, scott murray , sears. metal measuring appox 10.5 diameter x 4.5 " in depth Please advise If anyone has any for sale . Sal
Post by captbob on Jun 8, 2016 15:10:23 GMT -5
10.5 inches across? 10.5 x 4.5 would be a LOT more than a 6 lb barrel. Thumler's makes a nine pound barrel that is 7.5 x 4.5 which would give you your 4.5 to fit on the rods. It's called an A-R6 (but it's a 9 pound barrel - go figure) maybe you could just order the barrel. At the bottom of this page: www.thumlerstumbler.com/rotary.htmlI've got a boat load of older tumbler barrels out in my shed, I don't recall any of them being 10.5 inches across though. Will check next time out there.
salpal48
Post by salpal48 on Jun 10, 2016 14:55:53 GMT -5
10.5 inches across? 10.5 x 4.5 would be a LOT more than a 6 lb barrel. Thumler's makes a nine pound barrel that is 7.5 x 4.5 which would give you your 4.5 to fit on the rods. It's called an A-R6 (but it's a 9 pound barrel - go figure) maybe you could just order the barrel. At the bottom of this page: www.thumlerstumbler.com/rotary.htmlI've got a boat load of older tumbler barrels out in my shed, I don't recall any of them being 10.5 inches across though. Will check next time out there. Capbob I would be Interested in them If you can post a Picture.. This was I can see Condition. Sal
Post by Jugglerguy on Jun 10, 2016 17:10:58 GMT -5
Is the confusion over inside or outside diameter?
salpal48
Post by salpal48 on Jun 11, 2016 19:00:48 GMT -5
Yes, There is a confusion with Inside and out side. . These steel drums have been a standard In the Rock Tumbling Industry since the early 1960/ . They are all the same size . Round steel drums with segmented sides. , wheather it is a Highland park, Scott murray, Star diamonD, Craftools,. Or Sears., and early lortones. They are all the same. They are Not rubber . . There not new . i happen to need a Few . Sal
