Post by toiv0 on Jul 17, 2016 7:29:15 GMT -5
Last week we had a big storm up north here. Elderly neighbors had trees blow down that had been there since Christ was a child. I went over and cut them up and about the time I finished they came out with wood spitter. I just got done with all that and thought that I had a 90 lb piece of Mary Ellen I needed to resize to fit my smaller saw. So I ran home threw her in the truck and came back. You should have seen the look on their face when I threw Mary Ellen on the rack and held her down. Told'im to hit the lever and wallah now I have two pieces Mary and Ellen. jamesp would have been proud. So to make a long story longer. When I was younger I wanted a laboratory size rock crusher and everytime I had found one for sale it was gone about an hour before I got there. So here is my idea ...square metal box (heavy steel) maybe the bottome welded criss cross with hardened rod to help the break up. Plate that fit into box attached to an adjustable throw hydaulic cylinder. Manual or hrydraulic. I think it would be like magic, no flying pieces when you wack them with a hammer. Maybe one day I will tell the story of the hydraulic oil filter crusher.
wampidytoo
Add 5016 to my post count.
Member since June 2013
Post by wampidytoo on Jul 17, 2016 8:43:48 GMT -5
nowyo uses a hydraulic press to split rocks. I have not seen it in action but if I remember right he has a wedge point on top and just a flat plate on the bottom. More splitting than crushing action like you did with the log splitter. Maybe he will come on and give a better explanation. Jim
Post by jamesp on Jul 17, 2016 9:20:58 GMT -5
Gotta love hydraulics toiv0
Post by Drummond Island Rocks on Jul 17, 2016 13:47:51 GMT -5
Might not be hydraulic but here is a photo of the rock crusher that is used for all the rough that gets sent out for the Feather River Lapidary tumbling contest. Neat look piece of machinery. Rocks go in the hopper up top and come out the chute at the rear.
Post by jamesp on Jul 17, 2016 15:49:49 GMT -5
The rock shop that was once in North Atlanta had one just like it Chuck. that machine would be very costly tp build today.
Post by orrum on Jul 17, 2016 16:41:54 GMT -5
Looks like a gold ore crusher with a hit n miss engine. That's a antique for sure, is it a hammer mill or roller mill?
Post by Drummond Island Rocks on Jul 17, 2016 18:28:22 GMT -5
Looks like a gold ore crusher with a hit n miss engine. That's a antique for sure, is it a hammer mill or roller mill? Not sure what kind but it is not a gentle giant that is for sure Chuck
scottyh
Member since November 2007
Post by scottyh on Jul 17, 2016 19:40:52 GMT -5
Explains why my rough this year looked like it had been run over with a steam roller
Post by Drummond Island Rocks on Jul 17, 2016 19:48:24 GMT -5
Explains why my rough this year looked like it had been run over with a steam roller Adds to the challenge for sure. Used to be worse. The 2013 contest we had to send in 1/2 pound of finished tumbles not just five rocks. Chuck
Post by toiv0 on Jul 17, 2016 23:04:19 GMT -5
maybe an old jaw crusher
scottyh
Post by scottyh on Jul 18, 2016 1:32:15 GMT -5
Explains why my rough this year looked like it had been run over with a steam roller Adds to the challenge for sure. Used to be worse. The 2013 contest we had to send in 1/2 pound of finished tumbles not just five rocks. Chuck I couldn't even get half a pound out of the rocks that were sent to me. They were all fractured to the core
scottyh
Post by scottyh on Jul 18, 2016 1:33:51 GMT -5
Actually I told a fib.... I could have got a 1/2 pound of aquarium grit
Post by orrum on Jul 18, 2016 7:08:58 GMT -5
Dynamite maybe? If the use exploses it fractures to the core! Even huge boulders will b full of fractures. That's why Larry uses trachea to mine his Willow Creek claim. It's slow going thru solid rock but what you pull out is much better quality. He pulls out Volkswagon sized t eggs and then jackhammer them open and might only get a very small but beautif u center or gets nothing sometimes. It's a wonderful material tho.
Post by orrum on Jul 18, 2016 7:09:56 GMT -5
Trackhoe dang it spell check not trachea!!!
spiritstone
Member since August 2014
Post by spiritstone on Jul 18, 2016 9:18:55 GMT -5
Dynamite maybe? If the use exploses it fractures to the core! Even huge boulders will b full of fractures. That's why Larry uses trachea to mine his Willow Creek claim. It's slow going thru solid rock but what you pull out is much better quality. He pulls out Volkswagon sized t eggs and then jackhammer them open and might only get a very small but beautif u center or gets nothing sometimes. It's a wonderful material tho. There is wedge and feathers? or you could try drilling holes then use some kind of expansion material-agent. That is a 4 foot drill bit I am about to use in the pic. Good results when holes are spaced a foot apart. www.miconproducts.com/wedges.html
Post by orrum on Jul 18, 2016 11:58:17 GMT -5
I like the expanding stuff!!! Are you using bentonite?
