Post by manofglass on Sept 4, 2016 13:43:09 GMT -5
Post by Pat on Sept 4, 2016 13:44:59 GMT -5
Hmmmmm, what is it? Looks like you could drop bigger things in the top, machine would grind them up, and spit them in the bucket.
Hmmmm....?
Post by jamesp on Sept 4, 2016 16:45:46 GMT -5
Hmmmmm, what is it? Looks like you could drop bigger things in the top, machine would grind them up, and spit them in the bucket. Hmmmm....? That is a tumbler Pat with a trap door. It is eight sided. Looks like this:
Post by fernwood on Sept 4, 2016 18:28:57 GMT -5
Nice.
Post by manofglass on Sept 4, 2016 19:10:57 GMT -5
Or a Heavy duty" De-Burring machine that plastic liner is coming out if I have to cut it out
walt
Post by jamesp on Sept 5, 2016 4:46:11 GMT -5
You could use it for coarse grind Walt. No matter if grit gets stuck in it if just coarse grinding. Would be good to remove the liner and just have metal. Then you could run most grits except polish i suppose. Seems like polishing in a steel barrel would be a problem with metal stains.
