Post by jamesp on Sept 7, 2016 20:52:12 GMT -5
6 X 8 ! Does a slab that size rotate in the tub ? Would have never thought. If tumbling was a one minute operation the one sided thing would not be an issue. After time apparently there is going to be some shifting. On mine the faster the rocks roll the less separation. I went to rounder pea quartz media and the ball bearing effect sped the motion up and helped prevent separation go figure. jamesp My large tub is 9"X12" so there is room for them to rotate. I vibe 4-6 slabs at a time and have to separate them a few times a day. I use small pieces from making pendants and busted up junk slabs. The larger slabs actually stay apart longer................................MrP Forgot, you welded up a larger tub. For big slabs/more slabs. Nice.
