Post by manofglass on Sept 12, 2016 9:54:18 GMT -5
Is there a way to get rubber off of steel Without hurting the steel the rubber has Died and turned to plastic in some spots I been grinding it out of the steel tumbler Should be a easyer way to remove it
Walt
Post by pauls on Sept 12, 2016 16:21:43 GMT -5
Kerosene does horrible things to rubber, turns it to mush. When you are cleaning the mess out use disposable gloves, the black mess will stain your hands, get a box of gloves because they fall to pieces quickly with the kero.
stonedape
Member since July 2016
Post by stonedape on Sept 12, 2016 17:29:02 GMT -5
Is there a way to get rubber off of steel Without hurting the steel the rubber has Died and turned to plastic in some spots I been grinding it out of the steel tumbler Should be a easyer way to remove it Walt I would think acetone/nail Polish remover would work quick
Post by glennz01 on Sept 12, 2016 19:25:04 GMT -5
mineralspirits
Post by manofglass on Sept 12, 2016 19:34:31 GMT -5
any of that stuff cut urethane glue that is what they glued the rubber in with if I could find a urethane remover that works
walt
Post by manofglass on Sept 13, 2016 13:32:08 GMT -5
Is there a way to get rubber off of steel Without hurting the steel the rubber has Died and turned to plastic in some spots I been grinding it out of the steel tumbler Should be a easyer way to remove it Walt I would think acetone/nail Polish remover would work quick the acetone is working makes the room smell better to walt
Post by jamesp on Sept 13, 2016 15:39:49 GMT -5
I guess you could heat it up and soften the rubber. Not near acetone though !!
stonedape
Post by stonedape on Sept 15, 2016 14:37:18 GMT -5
Well? Did you get it all cleaned up?
Post by manofglass on Sept 15, 2016 15:00:00 GMT -5
It is sprayed in rubber no I don't have it cleaned Out yet got to do some more grinding To cut the rubber on the other side of the tank And around the opening I am working on this In the house trying not to burn the place down
Walt
stonedape
Post by stonedape on Sept 15, 2016 15:08:11 GMT -5
Gotcha. I was hoping my suggestion had done the trick!
Post by Rockoonz on Sept 15, 2016 23:02:39 GMT -5
Be careful with that acetone, it has a real low flash point. Used Xylene and MEK to loosen rubber from roller cores and molded in inserts in the day, work for a rubber company.
