beavens
Member since September 2016
Post by beavens on Sept 28, 2016 15:26:39 GMT -5
Hi all!
I recent got hooked on tumbling and would like a bit more predictability with what shapes I end up with.
Can you experts pointed me in the right direction? I'm working with rough I bought online that are about the right size, but I'm not sure the most efficient shaping method/gear.
I currently have a dremel 4000.
Thanks!
Jeff
richardh
Member since June 2016
Post by richardh on Sept 28, 2016 15:32:40 GMT -5
There are many others with tons more experience than me but I have been using a tile saw and am pleased with the results. I also tried a bench grinder but I think that is a bit too advanced for me as I always end up cutting my hands to pieces whenever I get it out.
beavens
Post by beavens on Sept 28, 2016 15:40:43 GMT -5
There are many others with tons more experience than me but I have been using a tile saw and am pleased with the results. I also tried a bench grinder but I think that is a bit too advanced for me as I always end up cutting my hands to pieces whenever I get it out. Thanks for the reply! Does the tile saw work well for smaller pieces (2-3") or are you at risk of losing a digit?
richardh
Post by richardh on Sept 28, 2016 16:28:03 GMT -5
I am using it to cut small pieces, most 1" or less. The continuous rim diamond blade doesn't cut soft things like fingers very well. So far I have managed to avoid being cut by the tile saw. You will definitely want to use safety glasses and hearing protection.
Post by captbob on Sept 28, 2016 16:30:04 GMT -5
The point of a tumbler (rotary) is to shape and smooth rocks. Pre-grinding just speeds things up.
beavens
Post by beavens on Sept 28, 2016 19:55:00 GMT -5
I am using it to cut small pieces, most 1" or less. The continuous rim diamond blade doesn't cut soft things like fingers very well. So far I have managed to avoid being cut by the tile saw. You will definitely want to use safety glasses and hearing protection. I appreciate the info! The point of a tumbler (rotary) is to shape and smooth rocks. Pre-grinding just speeds things up. Definitely, Bob. I was just looking for a little more control in terms of output.
Post by spiceman on Sept 28, 2016 20:42:40 GMT -5
Don't be in a hurry. Stage 1 rounding edges and corners. Pre grind just speeds up stage 1 and you can make the starting shape. Without pre grind you might not get the shape you want but it should still look good.
