Post by wampidytoo on Oct 18, 2016 19:33:58 GMT -5
Oh I am so jealous. I have no room, YET. Jim
Troll, Despicable. Wampidy in a past life. Artist, defender of the free world and stuff. Dumb sometimes but brilliant in others and I never know which one is going to pop out at any given time.
Always looking to purchase quality oddball colored Jasper's and Agates. If you want to part with some of your materials, give me a pm and let's work it out !
Thanks! I'm trying to figure out where to put it. It looks like it needs to be mounted on the counter so it doesn't walk itself right off the edge. So it might be a couple of days til I can use it.
I would leave it on the floor if possible. Even with the slurry thick it will throw a little mess. When I had a lap I happened to find a wooden crate the right size and about 6" taller than the lap. I removed front of crate for air flow. Then I covered the crate top edges with newspaper. As the newspaper got covered with slurry it was easy to replace. If you most have it on the counter you can attach a square frame to table to corral it.
Thanks for the tips John. I will see what I can do.
That is surprising. Does this mean that you loose most of your grit while it is working?
I am very interested because I am thinking about making one. I broke my vibrating tumbler and thought I could use it as the base for a flat lap. I don't care about the mess, but do care if the grit and moisture gets tossed away too quickly. I am thinking that maybe I should consider a high container or even one with a lid?
I'm so excited. This just got here. Can't wait to use it. I have so many end cuts and some slabs that I want to polish. Hopefully I can start today.
I'm am interested in that exact same one and been curious about it .... awesome to see someone here got one so they can give me some input on it Please feel me in when ya get it rolling a few times !!!
braders yesterday I started 4 pieces on the lap. I'm just following the instructions that came with it for now (except running them longer). paulshiroma shared what he does on another thread that I will be trying after these few. I will post pics when I'm finished.
It's not too bad but it's not in the house. We attached it to the counter and at first it was loud but I put a heavy bucket on the counter and it got quieter. Here it is along with three tumblers nearby. paulshiroma Are the rocks supposed to move around continuously? These seem to stay in one spot most of the time unless I move them.
Hey, congrats, meviva! AWESOME purchase! Yes, the rocks are supposed to sort of rotate around the pan. I noticed that the speed(?) at which they move changes with the grit size. With the coarse grit they sort of just casually move around. Lazy might be a better word. By the time I'm at the cerium oxide stage, they're moving around pretty well. It looks like you're on the initial coarse stage. Keep adding a bit of water now and then and as the grit breaks down and gets a bit "smoother" the rocks will slide around more. It's the sliding action that creates the polishing.
By the way, I might recommend you save up for an additional pan, pad and bumper and keep it solely for the (last) polishing stage. Then you won't be washing one pan out all the time risk any cross-contamination with the grits and the polish. If you decide to do a pre-polish stage with 1000 AO or just aluminum oxide polish, you can use the pad that came with your first pan. I end up not washing out the pads and just bagging them in some large trash bags so that I don't lose any 1000 AO or cerium oxide. My polishing pan and its pad is kept solely for the cerium oxide.
I like John's idea of getting a crate to sit the lap in. That's a great idea. This is one of the more messy tools that I've worked with.
Congrats again! I'm looking forward to trading ideas. Keep us posted on what works and doesn't work for you!
Paul
EDIT: I also neglected to mention a couple of items: 1. Whether or not the lap is level seems to make a difference in how well the rocks move around. Make sure to level the lap before anchoring it. And I still have to fiddle with it between grit changes. 2. Put a little motor oil or mineral oil on the screw that holds the pan in place. Mine got rusted and I couldn't get it out. I had to clip the ends and then drilled it out after which I had to find the right sized bolt, washers and nuts to secure the pan. The latter was easy, but drilling out the rusted-shut original bolt as a pain.
Last Edit: Oct 26, 2016 22:19:02 GMT -5 by paulshiroma
greig - You don't lose as much as it sounds like but the build up over time is rather surprising. You're going to have to constantly recharge this a bit faster than a tumbler as it seems to break down grit a bit faster. Might be my imagination but I do have to pay more attention to this tool than to the tumblers. The tumblers or are sort of "fire and forget" appliances. This one demands some attention as you go.
Post by johnjsgems on Oct 27, 2016 10:56:23 GMT -5
I too was going to mention leveling. Put a level across the pan in at least two directions and make sure it is level. If the rocks get stuck in one place you could end up with pans that are no longer flat.
amygdule: I don't remember where I buried it
Sept 21, 2024 14:03:04 GMT -5
parfive: Last night of summer and you can’t fix that w/a Sharpie.
Sept 21, 2024 22:39:07 GMT -5
1dave: Be the person to make others believe in good people again!
Sept 28, 2024 14:40:36 GMT -5
rocknrob: We could use more people like that now for sure. Or if being a nice person is too hard, just leave some tumbled agates around places where kids play for them to find!
Sept 28, 2024 20:14:18 GMT -5
Warzy Raptor: Just try being nice to -everyone-, you’ll be surprised at the results! My nasty supervisor will change her tone within five minutes when I kill her with kindness. And the local homeless lady Michelle and I have hour-long knee-slapping convos!
Sept 29, 2024 11:14:22 GMT -5
