tbvet3
Member since March 2016
Post by tbvet3 on Oct 19, 2016 9:25:29 GMT -5
What's the pros and cons of drip systems vs fountain systems for grinding wheels? Gonna be upgrading to diamond wheels and wondering which way to go. Right now I'm leaning towards the drip system cause gravity don't break.
I do mostly jasper and agate. Rough grind the cabs and then tumble for the finishing.
Thoughts anyone?
Thanks
Post by Drummond Island Rocks on Oct 19, 2016 10:38:05 GMT -5
fountains run in a pool of water which means any contaminates like rock chips or loose diamond particles can be sprayed up onto the wheels. Drip systems are adjustable from a light mist to a get you wet flow. The drip systems may require some cleaning once in awhile to clear clogs. I use drip on everything because I prefer to grind with more water flowing then fountains provide.
Post by Pat on Oct 19, 2016 14:29:24 GMT -5
I have fountain shooters that came with the Genie. stoner sings the praises of drip. Drips seem like they would be better to me, too, as stated above.
tbvet3
Post by tbvet3 on Oct 19, 2016 16:47:47 GMT -5
Thanks team.
70karmann
Member since February 2011
Post by 70karmann on Oct 20, 2016 0:22:35 GMT -5
Drip-drip-drip
Post by orrum on Oct 20, 2016 6:28:47 GMT -5
Drip drip x2
Post by bobby1 on Oct 20, 2016 9:18:19 GMT -5
Drip, fast drip, up to gushing. However I have Genies that I teach on where I have installed aquarium air pumps with Kingsley North high volume water geysers simply because the original system just doesn't give me as much water as I would like. Bob
Post by Tommy on Oct 27, 2016 12:21:49 GMT -5
I built a recirculating drip - similar to what Bob described above except water is delivered to each wheel from the top, slow drip-to-gushing stream. Details available if anyone cares lol.
Post by Pat on Oct 27, 2016 12:32:25 GMT -5
I built a recirculating drip - similar to what Bob described above except water is delivered to each wheel from the top, slow drip-to-gushing stream. Details available if anyone cares lol. Tommy, pictures? Thanks!
