omarfarouk
Member since November 2016
Post by omarfarouk on Nov 7, 2016 17:21:47 GMT -5
Hello im omar from egypt and im stabilized stones by epoxy 300 and i have problem i dont need epoxy coming harder want it liquied with the hardener is there where anything can help me for making epoxy liquid for long time Hope i can get this information i will wait your reply Thank you Omar
Sent from my iPhone using Tapatalk
Post by Deleted on Nov 7, 2016 19:59:14 GMT -5
Hello im omar from egypt and im stabilized stones by epoxy 300 and i have problem i dont need epoxy coming harder want it liquied with the hardener is there where anything can help me for making epoxy liquid for long time Hope i can get this information i will wait your reply Thank you Omar Sent from my iPhone using Tapatalk It stays liquid forever. Just don't mix the two parts. You must search for slow setting examples if you insist on mixing it.
omarfarouk
Post by omarfarouk on Nov 8, 2016 6:26:51 GMT -5
Thank you for reply but you dont understand me in my processes i need to mix both of them without make it coming harder for 20 days so what i can do for make this mix and not coming harder
NDK
Post by NDK on Nov 8, 2016 8:30:25 GMT -5
Search how to stabilize rock with epoxy.
I've read (no personal experience) mixing with acetone and storing in an airtight container keeps it from setting up.
rxscram
Member since August 2011
Post by rxscram on Nov 8, 2016 16:20:30 GMT -5
Thank you for reply but you dont understand me in my processes i need to mix both of them without make it coming harder for 20 days so what i can do for make this mix and not coming harder What are you trying to do? (Why do you want it to not be hard for 20 days?) The whole point of mixing the epoxy with the hardener is to make it solidify. If you don't want it to solidify, you can't mix them together.
omarfarouk
Post by omarfarouk on Nov 8, 2016 16:27:15 GMT -5
Thank you for reply but you dont understand me in my processes i need to mix both of them without make it coming harder for 20 days so what i can do for make this mix and not coming harder What are you trying to do? (Why do you want it to not be hard for 20 days?) The whole point of mixing the epoxy with the hardener is to make it solidify. If you don't want it to solidify, you can't mix them together. I use it to stabilized stones and i must mix it for make stones coming harder so i need a matrial i can put it in the mix for make it coming longer time to make stones coming harder that all
Post by Deleted on Nov 8, 2016 17:45:29 GMT -5
What are you trying to do? (Why do you want it to not be hard for 20 days?) The whole point of mixing the epoxy with the hardener is to make it solidify. If you don't want it to solidify, you can't mix them together. I use it to stabilized stones and i must mix it for make stones coming harder so i need a matrial i can put it in the mix for make it coming longer time to make stones coming harder that all Experiment using less hardener (the smelly yellow stuff)
