joejansal
![*](//storage.proboards.com/forum/images/stars/star_orange.png)
Member since August 2009
Post by joejansal on Nov 9, 2016 10:27:48 GMT -5
hi all looking for info on a recirculating pump when drilling with core drill bits using a shallow pan of water the water gets cloudy real quick, would like to run hose into bucket and filter out the dust any ideas will be appreciated. also any tricks to letting the plugs come out of core 11mm drill bits, I use the plugs for beads. thank you joejan
Post by 150FromFundy on Nov 9, 2016 17:10:19 GMT -5
Check out an aquarium shop for a pump that uses small diameter plastic tubing for connections. Many of the pumps use a cotton like filter media that may tend to clog up quite quickly with rock dust water.
When I drill, I simply drain and replace the water as it gets cloudy, but that can get to be a chore.
Darryl.
