meviva
Member since July 2013
Post by meviva on Nov 13, 2016 21:01:38 GMT -5
I'm finally starting to work with the slabs I've been cutting. They are sitting in a bowl of water to show the colors. Andrea ![](http://i1122.photobucket.com/albums/l528/meviva2/Mobile%20Uploads/E7E41A96-5757-4728-8D3F-439099D71606_zpsp1c3tcuh.jpg)
Post by paulshiroma on Nov 13, 2016 21:26:42 GMT -5
Looking good and looking forward to seeing your results! Paul
Post by Tommy on Nov 13, 2016 21:52:25 GMT -5
Nice! Those Montanas are going to be off the charts.
dottyt
Member since July 2016
Post by dottyt on Nov 14, 2016 0:17:11 GMT -5
Lovely colors and shapes!
Post by Deleted on Nov 14, 2016 0:20:10 GMT -5
Boom!
Post by orrum on Nov 14, 2016 10:12:06 GMT -5
Them b mighty fine!
Post by HankRocks on Nov 14, 2016 10:30:51 GMT -5
just curious, what is the purpose of the marked line offset from the edge?Beveling line maybe? Are these just from cutting on the saw? and what type of saw?.
I have been cutting out preforms on a 7 inch tile saw and mine leave a good bit for the rough grind to get to the finish shape. Yours seem a lot smoother than I am able to do.
H
Post by Drummond Island Rocks on Nov 14, 2016 10:57:31 GMT -5
Nice little teaser photo. Going to be some great cabs.
meviva
Post by meviva on Nov 14, 2016 11:08:00 GMT -5
just curious, what is the purpose of the marked line offset from the edge?Beveling line maybe? Are these just from cutting on the saw? and what type of saw?. I have been cutting out preforms on a 7 inch tile saw and mine leave a good bit for the rough grind to get to the finish shape. Yours seem a lot smoother than I am able to do. H I used a tile saw to get close to the lines I drew but then used a grinder to get to this point. The lines will be ground off on the Genie next by turning the preform upside down and making a beveled edge. I'm going to retrace the template on the bottom so I don't lose the shape. Andrea
metalsmith
Post by metalsmith on Nov 18, 2016 8:27:31 GMT -5
I would try to keep a thin line of clear / translucent around the big spots... but that's just me. OCD? Yes ...
But why cut away much more than you have? Just tidy up the cut lines and you're home. The lines won't survive the higher grades / polish anyway. Just my 2c...
Post by stardiamond on Nov 19, 2016 13:01:43 GMT -5
just curious, what is the purpose of the marked line offset from the edge?Beveling line maybe? Are these just from cutting on the saw? and what type of saw?. I have been cutting out preforms on a 7 inch tile saw and mine leave a good bit for the rough grind to get to the finish shape. Yours seem a lot smoother than I am able to do. H I used a tile saw to get close to the lines I drew but then used a grinder to get to this point. The lines will be ground off on the Genie next by turning the preform upside down and making a beveled edge. I'm going to retrace the template on the bottom so I don't lose the shape. Andrea That is the same way I do it. The top is to get the general shape of the cab and the bottom is where the cab is cut from. I always leave a little room with the top lines in case something goes wrong or the bottom chips. After grinding the bottom edge to 280, I mark the girdle and a center line on the top. I grind from the girdle line to the center line.
Post by accidentalrockhound on Nov 27, 2016 13:35:58 GMT -5
Very nice pieces, how thick are they to start can't wait to see the finished cabbs,
meviva
Post by meviva on Nov 28, 2016 11:45:33 GMT -5
Very nice pieces, how thick are they to start can't wait to see the finished cabbs, Thanks. They are about a quarter of an inch thick. I started working on them last night. They got to the 600 wheel but a couple have to go back for a little more work.
Post by pghram on Dec 2, 2016 15:21:10 GMT -5
Anxiously awaiting the finished cabs.
Peace,
Rich
meviva
Post by meviva on Dec 5, 2016 14:17:45 GMT -5
I started working on them but then the week got so busy with other things I haven't finished them. Hopefully soon.
Andrea
meviva
Post by meviva on Jan 19, 2017 20:04:36 GMT -5
Post by accidentalrockhound on Jan 19, 2017 21:45:15 GMT -5
Wow great cabbs them are super shiny!! What are the plans for them?
Post by pghram on Jan 19, 2017 22:00:19 GMT -5
Beautifully crafted!
Peace,
Rich
ziggy
Member since June 2016
Post by ziggy on Jan 19, 2017 22:06:04 GMT -5
Amazing cabs. I like the one in the second picture down best.
Post by Bluesky78987 on Jan 20, 2017 15:53:12 GMT -5
Beautiful! I love seeing before and after pictures.
