Post by broseph82 on Nov 14, 2016 9:52:21 GMT -5
Looking for advice as to the proper substance to clean these with (rag with PB blaster?) and should I grease them up after and with what grease? Untitled by Jimi Sitko, on Flickr Untitled by Jimi Sitko, on Flickr
Post by broseph82 on Nov 14, 2016 10:34:59 GMT -5
Asked on FB and got clean excess grease, regrease with marine grade grease and voila. done. wish me luck
Post by Fossilman on Nov 14, 2016 11:29:27 GMT -5
In the old days,we used diesel fuel and an air gun,than repacked the bearings with grease.....
Post by jakesrocks on Nov 14, 2016 12:20:16 GMT -5
Looks like a lot of metal in that old grease. Those bearings may be beyond saving. You can try, but I'd suggest replacing them with sealed pillow bearings.
ziggy
Member since June 2016
Post by ziggy on Nov 14, 2016 15:06:30 GMT -5
Asked on FB and got clean excess grease, regrease with marine grade grease and voila. done. wish me luck Great advice if you first make sure that they are even usable. Check for play and runout. Feel how smoothly the bearings roll in their race by hand. Any roughness and you should toss em. When you regrease, clean off old grease from the outside. Inject new grease until new grease ejects old grease then wipe off old grease again. It is perfectly normal for normal pillow blocks to pass grease past the seals when being filled. If you replace them with sealed pillow blocks, be ready to replace again someday. My course of action if they are not reusable would be to replace them with new pillow blocks that can be greased at regular intervals and then following through on the greasing at regular intervals. Properly greased and installed bearings should last for decades. Unless, lets say, they're made in China. Sealed pillow blocks are great at resisting water and should be used where water is invasive. The only problem with them is that all grease will eventually loose some of its qualities and with noway to replace it with clean new grease, it just gets worse and worse until the bearing fails (usually way before a properly maintained lubricatible bearing would.)
Post by spiceman on Nov 14, 2016 21:19:01 GMT -5
It's easier just to replace them. Not much cost and saves lots of time and hassle the big thing....you know for sure the are good.
Post by spiceman on Nov 14, 2016 21:19:38 GMT -5
Post by broseph82 on Nov 14, 2016 22:19:56 GMT -5
Looks like a lot of metal in that old grease. Those bearings may be beyond saving. You can try, but I'd suggest replacing them with sealed pillow bearings. What do you mean it looks like a lot of metal in that old grease? I cleaned what I could with just a rag and they don't look bad and they both turn fine by hand. Not sure why everyone just thinks they're junk at this point
Member is Online
Post by quartz on Nov 14, 2016 23:01:29 GMT -5
I've cleaned up, rolled for smoothness, relubed, and gotten good service out of lots of pillow blocks that came on things I bought. Given your description, I don't think they're junk.
Post by jakesrocks on Nov 14, 2016 23:25:03 GMT -5
Looks like a lot of metal in that old grease. Those bearings may be beyond saving. You can try, but I'd suggest replacing them with sealed pillow bearings. What do you mean it looks like a lot of metal in that old grease? I cleaned what I could with just a rag and they don't look bad and they both turn fine by hand. Not sure why everyone just thinks they're junk at this point Just going on years of personal experience, and the silver colored specks I see in the grease in your pics.
Post by Rockoonz on Nov 14, 2016 23:29:58 GMT -5
They don't make Sealmaster bearings anymore and they last waaaay longer than the new imported ones.
ziggy
Post by ziggy on Nov 15, 2016 10:23:07 GMT -5
It's easier just to replace them. Not much cost and saves lots of time and hassle the big thing....you know for sure the are good. I would respectfully disagree. He has already stated that the bearings are in working condition. I believe it would be way easier to wipe them off, inject new grease and be done. With your solution, an extra expenditure is involved in the purchase of new bearings. Plus, you still need to grease the new bearings too. Grease and rags cost way less.
ziggy
Post by ziggy on Nov 15, 2016 20:28:38 GMT -5
They don't make Sealmaster bearings anymore and they last waaaay longer than the new imported ones. They still make and sell Sealmaster. Sealmaster is a model name used by the manufacturer named Regal. link
salpal48
Member since March 2015
Post by salpal48 on Nov 23, 2016 15:17:02 GMT -5
I found the best way to Clean Then #1 mineral spriits. Let them soak. #2 Kroil. . will desolve Most Sal
bills
Member since March 2016
Post by bills on Nov 23, 2016 16:02:47 GMT -5
NO don't soak them just wipe them down they are sealed bearings and the solvent will allow the dirt and grit in. use lithium #2 grease and do not over grease them if you see grease coming out of the seals you are over greasing them.
