Post by jamesp on Nov 21, 2016 15:25:49 GMT -5
It was not cheap. Glad to have her running after a long sit. Used oversize 10 gauge wire. Making sure there was little resistance. Tight spot to work in. Used stainless allen head bolts. Lock washers both sides. Used a grinder to remove the old bolts as they were rusted and difficult to remove. [img src="https://c2.staticflickr.com/6/5822/30340731334_06c6cc3700_b.jpg" alt=" "
Post by captbob on Nov 21, 2016 15:46:32 GMT -5
Back in business!
Post by rockpickerforever on Nov 21, 2016 16:11:57 GMT -5
YAY! You need more things to do (jk)
Post by Fossilman on Nov 21, 2016 16:44:59 GMT -5
Ok,get going on some tumbles!!!!
Post by Deleted on Nov 21, 2016 17:06:59 GMT -5
Post by HankRocks on Nov 21, 2016 17:14:18 GMT -5
I see it's a double shaft motor. Is there a vibration mechanism that the belts connect to on rest of the tumbler. I am not familiar with the Viking unit.
H
Post by jamesp on Nov 21, 2016 17:46:38 GMT -5
The Viking is hungry, needs Vitamin R !!
Post by jamesp on Nov 21, 2016 17:52:11 GMT -5
I see it's a double shaft motor. Is there a vibration mechanism that the belts connect to on rest of the tumbler. I am not familiar with the Viking unit. H Here ya go Henry. The 14 pound capacity hopper bolts to the top of this cover. Yes, stretchy O-ring belts isolate vibration from motor.
Post by orrum on Nov 21, 2016 18:15:34 GMT -5
Get her to wiggling and dancing Jim!!!
Post by tims on Nov 21, 2016 18:26:19 GMT -5
Yay! Hope that new motor gives you as many miles as the original.
Post by jamesp on Nov 21, 2016 18:28:57 GMT -5
Get her to wiggling and dancing Jim!!! Wish we could replace our motors like that Bill.
Post by jamesp on Nov 21, 2016 18:34:49 GMT -5
Yay! Hope that new motor gives you as many miles as the original. Has sleeves instead of bearings and a much lower service factor(SF). Old school will out last this one hands down. If yours says GE then you got the old reliable. However, judging from the wires it looks like another motor was spliced in before this one. Guessing this one has had some extensive use.
Post by Pat on Nov 21, 2016 18:41:54 GMT -5
Ummmm, that's nice! What can it do?
Post by jamesp on Nov 21, 2016 19:43:26 GMT -5
Ummmm, that's nice! What can it do? Polish them rocks Pat.
Post by wigglinrocks on Nov 22, 2016 0:40:09 GMT -5
Really like your , don't just fix it , fix it right attitude
Post by jamesp on Nov 22, 2016 2:40:13 GMT -5
Really like your , don't just fix it , fix it right attitude Functional but not so pretty wigglinrocks.
