hogan
Member since May 2014
Post by hogan on Dec 2, 2016 19:10:21 GMT -5
Do any of you guys use power tools to remove pitting in rough prior to tumbling? I would think that there would be a lot of material saved rather than trying to tumble all of the pits and crevasses out during the process.
Post by wigglinrocks on Dec 2, 2016 19:21:03 GMT -5
Yup , grinder , dremel , saw , take your pick . Yes , grinding out pits and other flaws is a huge time saver .
bsky4463
Member since September 2013
Post by bsky4463 on Dec 2, 2016 19:21:12 GMT -5
check out some of jamesp 's threads he is a master at the pre-tumble grind....
Post by MrMike on Dec 2, 2016 19:34:45 GMT -5
check out some of jamesp 's threads he is a master at the pre-tumble grind.... Take it slow when getting into the jamesp threads or your head could explode.....he has it down to a science.
Post by jamesp on Dec 2, 2016 19:38:27 GMT -5
check out some of jamesp 's threads he is a master at the pre-tumble grind.... Andy-found a chunk of rhyolite that is a carbon copy of your Montana stuff. Certain it did not wash down from your area. But somewhere upstream Texas or Mexico made duplicate rhyolite. I wear ear protection, breathing protection and eye protection. Very very cautious of fingers. Love shaping rocks on this rig, then slapping a tumble finish them. Welcome to the forum hogan. Turn volume down.
Post by jamesp on Dec 2, 2016 19:46:37 GMT -5
Can also be used as a high speed hammer to chip larger pieces before grinding.
bsky4463
Post by bsky4463 on Dec 3, 2016 20:48:03 GMT -5
[/quote]Andy-found a chunk of rhyolite that is a carbon copy of your Montana stuff. [/quote]
Awesome @ jamesp ! (Well actually bummer for me, as that means my line on Killa GA corral is toast!). Cheers
Post by jamesp on Dec 3, 2016 21:20:57 GMT -5
Andy-found a chunk of rhyolite that is a carbon copy of your Montana stuff. [/quote] Awesome @ jamesp ! (Well actually bummer for me, as that means my line on Killa GA corral is toast!). Cheers[/quote] Only one single piece, no competition for your Montana stuff. Nothing as banded as yours. But it has the purple tint.
