Post by jamesp on Dec 11, 2016 12:21:10 GMT -5
I made a mistake on the size of the aluminum oxide. It is AO 46 and AO 80 instead of AO 80 and AO 220. No matter, it only means that a nice polish was made using AO 46 or AO 80 with Borax in the vibe before moving to AO 14,000 polish. Either AO 46 or AO 80 gives a real nice pre-polish in 2 days with Borax in the vibe. SiC 220 never gave near the pre-polish AO 46/AO 80 gave even after 4 days. Not sure there is any good reason to use SiC 220 in a vibe if using AO 46 or AO 80. To identify the size of the AO 80, SiC 220 particles and AO 80 particles were placed on an index card and photographed with camera on magnification mode. SiC 220 is black, AO 80 is yellow and clear
Post by 1dave on Dec 11, 2016 23:10:06 GMT -5
Where do you get your AO 80 - Harbor Freight?
Post by jamesp on Dec 12, 2016 1:57:52 GMT -5
Where do you get your AO 80 - Harbor Freight? I found a 5 gallon bucket cheap at an industrial junkyard. Label said blasting media Dave. Don't have the original label. Thought it was 220, but not. Needed to know because it serves so well in the vibe. It seemed too coarse to be 220. So the photo comparison. Going to try it in the rotary and see if I can skip 220-500-1000 steps in the rotary. It does that in the vibe....why not the rotary. Tumbling suppliers don't carry AO 80. Rarely AO 220. Never AO 46. I remember getting an odd polish on a rotary barrel I ran once long ago. The rocks came out polished. I thought I had AO 46 in it. Seen the polish and figured I made a mistake on the grit. After using AO 46 and AO 80 in the vibe and getting an easy polish in 2 days I think it was AO 46 in the rotary after all. Now I am thinking a coarse AO may take you all the way to polish in a rotary. I started another experiment in the rotary. Clay slurry with hammer broken SiC 60 grinding wheel chunks. "Time Release" SiC 60. To avoid adding SiC 30 daily. Added 2 cups of chunks. 4 times the normal 1/2 cup daily dose. Will have to thin slurry guessing every 5 days, add chunks. Never used the chunks with clay slurry.
Post by MrMike on Dec 12, 2016 6:25:46 GMT -5
Where do you get your AO 80 - Harbor Freight? I found a 5 gallon bucket cheap at an industrial junkyard. Label said blasting media Dave. Don't have the original label. Thought it was 220, but not. Needed to know because it serves so well in the vibe. It seemed too coarse to be 220. So the photo comparison. Going to try it in the rotary and see if I can skip 220-500-1000 steps in the rotary. It does that in the vibe....why not the rotary. Tumbling suppliers don't carry AO 80. Rarely AO 220. Never AO 46. I remember getting an odd polish on a rotary barrel I ran once long ago. The rocks came out polished. I thought I had AO 46 in it. Seen the polish and figured I made a mistake on the grit. After using AO 46 and AO 80 in the vibe and getting an easy polish in 2 days I think it was AO 46 in the rotary after all. Now I am thinking a coarse AO may take you all the way to polish in a rotary. I started another experiment in the rotary. Clay slurry with hammer broken SiC 60 grinding wheel chunks. "Time Release" SiC 60. To avoid adding SiC 30 daily. Added 2 cups of chunks. 4 times the normal 1/2 cup daily dose. Will have to thin slurry guessing every 5 days, add chunks. Never used the chunks with clay slurry. Very interesting James. So the AO keeps rounding off to smaller sizes & you get a corresponding finer polish? The longer you leave it the finer the polish. Sounds logical. I'm definitely going to try this in the rotary. THANKS
Post by jamesp on Dec 12, 2016 7:57:24 GMT -5
AO 80 has done that in the vibe 6 straight runs MrMike. In two days each. I don't see why it would'nt do it in a rotary. It would take longer than a vibe though. Probably best to final finish with a polish run though. BUT, you have to use SiC 30-45/70-60-etc to round your rocks initially.
Post by jamesp on Dec 12, 2016 8:20:17 GMT -5
The Washington Mills sales agent used to drop by the house. Washington Mills makes most of the US SiC. Other abrasives.
We traded my rocks for his abrasive samples.
List of 5 pound samples he gave me in trade. Long used up over the years:
SiC 8, SiC 16, SiC 46, SiC 500, SiC 1000
AO 46, AO 60, AO 400, AO 800. The AO 46 was a 5 gallon bucket.
These were industrial abrasives. About the same as tumbling abrasives, just more costly because they were precision graded in size.
Then I acquired samples from garnet abrasive companies(best for tumbling metals):
270 garnet, 300 garnet, 400 garnet and 4 garnet. The 4 garnet makes great filler media in vibe or rotary
From Lortone:
Lortone pre polish AO, which is a range of aluminum oxide from 200-1000, particles averaging 600.
Lortone experimental AO polish, which was a range of aluminum oxide from 1000 to 6000 averaging 3000
Discussed the wide range of sizes with the Lortone technical guy. He was first to explain how aluminum oxide smooths. That the wide range of sizes did not matter so much, all the particles are going to become smooth and impart a polish. That Lortone's AO pre-polish was an inexpensive grade of AO because it was not precision sifted to one grade size. And that it did not matter in tumbling rocks.
From an industrial junkyard:
AO 80, 5 gallon bucket. Plain sand blasting abrasive.
Other samples from other abrasive companies like Kramer.
osuguy0301
Member since December 2015
Post by osuguy0301 on Jan 8, 2017 7:45:28 GMT -5
jamespI was on Harbor Freight and noticed they have "black Aluminum Oxide 70 grit abrasive media." I am assuming this would be similar to the AO 80 that you are talking about or is this something completely different? I got a harbor freight right up the road but I don't wanna buy 25 lbs if its the wrong stuff. I have been following your posts and I like the idea of having to do less clean outs in my vibe. Also, where do you get your AO 14,000 for your polish step? Thanks, Jake
Post by jamesp on Jan 8, 2017 8:56:06 GMT -5
jamespI was on Harbor Freight and noticed they have "black Aluminum Oxide 70 grit abrasive media." I am assuming this would be similar to the AO 80 that you are talking about or is this something completely different? I got a harbor freight right up the road but I don't wanna buy 25 lbs if its the wrong stuff. I have been following your posts and I like the idea of having to do less clean outs in my vibe. Also, where do you get your AO 14,000 for your polish step? Thanks, Jake Jake To avoid any possible problems please order this AO 80 from Ebay. 10 pounds for $15 + $7 shipping. I have used this supplier's AO 80 and AO 24 with perfect results. I have also used the brown AO 46 and AO 80 with same results. This supplier's AO looks white but it is actually dead clear and it is a crushed form that breaks down quickly. I don't think shape or color matters really. Feel certain the black would work. I look at the color of the slurry too. I would not care for a potentially black slurry. 10 pounds will last a long time running 6 and 12 pound barrels. Ebay link www.ebay.com/itm/121591344289?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AITRock Shed is the source for AO 14,000. It is popular on his forum, tried and tested many times over. I tried buying AO 60-70-80 from the Rock Shed but he does not carry it.
osuguy0301
Post by osuguy0301 on Jan 9, 2017 16:00:35 GMT -5
jamesp I was on Harbor Freight and noticed they have "black Aluminum Oxide 70 grit abrasive media." I am assuming this would be similar to the AO 80 that you are talking about or is this something completely different? I got a harbor freight right up the road but I don't wanna buy 25 lbs if its the wrong stuff. I have been following your posts and I like the idea of having to do less clean outs in my vibe. Also, where do you get your AO 14,000 for your polish step? Thanks, Jake Jake To avoid any possible problems please order this AO 80 from Ebay. 10 pounds for $15 + $7 shipping. I have used this supplier's AO 80 and AO 24 with perfect results. I have also used the brown AO 46 and AO 80 with same results. This supplier's AO looks white but it is actually dead clear and it is a crushed form that breaks down quickly. I don't think shape or color matters really. Feel certain the black would work. I look at the color of the slurry too. I would not care for a potentially black slurry. 10 pounds will last a long time running 6 and 12 pound barrels. Ebay link www.ebay.com/itm/121591344289?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AITRock Shed is the source for AO 14,000. It is popular on his forum, tried and tested many times over. I tried buying AO 60-70-80 from the Rock Shed but he does not carry it. Thanks for the eBay link. I think I will place an order for that here shortly and give that a try. The black looks pretty dark, even darker than a SiC 60/90 so I didn't know how that would work out. I looked on the Rock Sheds page for the AO 14,000 but all I could find was just Aluminium Oxide polish. Is that the same? If so I already have 5 lbs of it and should be good to go. Thanks for all the info, Jake
Post by jamesp on Jan 9, 2017 17:12:42 GMT -5
osuguy0301Rock Shed's AO polish is AO 14.000. It averages 1 micron. Fine polish. Glad you are going with the clear AO 80. Never ran the black. It is probably like clear black glass and may have little coloring. AO comes in many colors. Don't think the color matters one iota. The clear AO 80 run with Borax in the vibe makes a pretty dead white Milk of Magnesia slurry. And milky in the rotary. You were going to use it in the rotary. I would avoid kitty litter or clay. Sugar if you feel so inclined. One cup/10 pounds rock. May go a bit light on the water level to make sure it sticks to the rocks. At least for the first day or two. Run for at least 10 days. Longer will not hurt, only help.
osuguy0301
Post by osuguy0301 on Jan 9, 2017 18:57:03 GMT -5
jamespI was going to try it in my smaller rotary, 4.5 lb, first. Can it not be used in a vibe? Wouldn't mind using it in my Loto if it would work. Would save on clean outs and grit if it will work. Jake
Post by jamesp on Jan 9, 2017 19:22:49 GMT -5
jamespI was going to try it in my smaller rotary, 4.5 lb, first. Can it not be used in a vibe? Wouldn't mind using it in my Loto if it would work. Would save on clean outs and grit if it will work. Jake My eyes were first opened by AO 80 in the vibe. By accident. I was smoothing rocks out of rotary run in SiC 30. Came back 24 hours later and the rocks in the vibe with AO 80 had a decent polish. Since, I have used the AO 80 in my vibe a dozen times now. 2-3 days with Borax. Then straight to polish with AO 14,000 with borax in the vibe for 18 hours. All went fine. Polish achieved. A month ago I questioned if AO 80 would work in the rotary. Tried it. It worked. Only difference is it takes 10 days for the rotary to break it down. (2-3 days in the vibe). Makes perfect sense, the vibe breaks grit down way faster. Two 10 day runs with AO 80 and one 10 day run with AO 24. All three runs finished in 18 hours with AO 14,000 in the vibe. Polish achieved. Beware. Running 80 grit is not recommended by many vibe manufacturers. Not sure if that were referring to SiC 80 or AO 80. But AO 80 is much less aggressive than SiC 80. SiC is way sharper. I will say that AO 80 is probably not very aggressive after the first 4-8 hours in the vibe. So it may not be worth worrying about. And my vibe may be different than your vibe. Results may vary. I doubt it. I say give it a go. AO 80 is about a guaranteed replacement for SiC 220. So it won't go wasted.
osuguy0301
Post by osuguy0301 on Jan 9, 2017 19:26:54 GMT -5
jamespThanks for all the info. I really appreciate it and I will let ya know how it all works out. Thanks, Jake
Post by jamesp on Jan 9, 2017 19:30:55 GMT -5
jamespThanks for all the info. I really appreciate it and I will let ya know how it all works out. Thanks, Jake All I can say is it simplified my tumbling process. Good luck.
rastageezer
Member since December 2013
Post by rastageezer on Jan 10, 2017 2:35:32 GMT -5
Jim, just ordered some of that guy's AO 80 from the link to ebay. Gonna run it in the Lot-O. Worth a try! (Texas, Montana, Lakers)
Post by jamesp on Jan 10, 2017 9:38:18 GMT -5
Jim, just ordered some of that guy's AO 80 from the link to ebay. Gonna run it in the Lot-O. Worth a try! (Texas, Montana, Lakers) I use 2 tablespoons in a 14 pound vibe. 2 tablespoons Borax. Rock dripped dry after wetting and quickly put in hopper. In my vibe the rocks stay on the wet side, Borax not getting pasty, closer to milk. Check moisture daily, Lot-O may dry quicker, I have no idea about a Lot-O. Add just enough water to maintain milk slurry. To clean I use Dawn-with hopper running(with AO 80) pour water in it say 3/4 full and add ~tablespoon of Dawn. Let run 5 to 10 minutes. Lot-O is 4-5 pounds ? Maybe 80% of a tablespoon rasta, 80% of tablespoon Borax. By day one you may have a sheen started. By day two you should have a polish starting. After 2-3days transfer to AO polish. Good luck.
osuguy0301
Post by osuguy0301 on Jan 11, 2017 15:58:09 GMT -5
I just ordered a bag today also. Should be here by Saturday. Plan on using it once I get enough stuff from my 60/90 runs.
Post by jamesp on Jan 11, 2017 16:22:33 GMT -5
I just ordered a bag today also. Should be here by Saturday. Plan on using it once I get enough stuff from my 60/90 runs. What type of vibe do you have ?
osuguy0301
Post by osuguy0301 on Jan 11, 2017 16:26:41 GMT -5
Single barrel Loto, like Rasta
Post by jamesp on Jan 11, 2017 16:45:58 GMT -5
Single barrel Loto, like Rasta Far out. Efficient machines. Never had one but see how they lay down a wicked polish. Should be no different from my Viking. I
