mikeinsjc
Member since June 2010
Post by mikeinsjc on Jan 8, 2017 20:46:38 GMT -5
I am thinking about buying one. Does anyone have any experience/recommendations?
Post by MrP on Jan 9, 2017 6:07:30 GMT -5
mikeinsjc
Jun 8, 2015 18:31:19 GMT -6 MrP said:
I have a LUD150 that originally came from here. I have talked to Bill a number of times and he has been a great help. I also order my drill tube and silver solder from him.
I can tell you that when everything is right it is great. I know that the horn has to be the right shape and length to work correctly. I have almost 30 horns and have found that certain ones only like a certain drill tube size. If everything is not right the vibrations do not end up at the tip so the drill tube will break off or you can not get it to drill.
I found there was a learning curve to figuring the drill out but once that happens all is good. Beats the heck out of diamond drills.
Good luck in building one..............................MrP
mikeinsjc
Post by mikeinsjc on Jan 9, 2017 11:04:58 GMT -5
MrP, thanks for the advice. I have heard the LUD units have been around a long time. One of my concerns is getting parts and advice on the LUD unit- the website doesn't inspire a lot of confidence. You have had no problem here?
