Post by takecouragedesigns on Jan 16, 2017 16:06:24 GMT -5
If only there was a schematic diagram online for these machines! Thanks to the kind help of Don at Diamond Pacific, I ordered the requisite parts still needed to assemble our Genie "from the ground up". The parts arrived, but Don is out of commission (in Quartzite) as far as being able to help in the "what goes where" of this machine. We've got the easy parts of it together, but are now stuck regarding setting up the shaft adapters. A picture would be worth a thousand words if anyone here with a genie/titan or even pixie would be willing to show how the adapters are set up (RH Adapter- there's a nylon ring, an aluminum ring, and a grooved pulley ring (?). Don't know which order those go in, for instance. Even a simple written description would so help us get unstuck! We're soooo close to having my hubby's "new" toy ready to go! Thanks to all of you patient and helpful lapidarys, here
Post by melhill1659 on Feb 2, 2017 0:21:10 GMT -5
Hello, I'm not sure if I can help but I have a Genie so I may be able to take the pictures you need. Even though I'm not sure how to interpret "ground up" . Mel
Post by Pat on Feb 2, 2017 0:56:13 GMT -5
Yikes! How did you get an unassembled Genie? I can't imagine the difficulty. Good luck.
gemfeller
Member since June 2011
Post by gemfeller on Feb 2, 2017 18:43:40 GMT -5
I'm not sure what you're calling a "shaft adapter." I recently installed a shaft adapter on the RH side of my Genie so I could run extra wheels. You simply put the wheels on the adapter, arranging them with the plastic spacers, then slide the adapter onto the shaft and rotate it clockwise while holding the LH wheels until it's hand-tight.
But from your description I'm thinking you have another part in mind. You might start by giving us a somewhat more complete description of your project and more specific info on your "shaft adaptor."
Post by Pat on Feb 2, 2017 18:50:38 GMT -5
... and photos of what you have... Thanks!
