sdrockgal
Member since December 2016
Post by sdrockgal on Jan 17, 2017 13:35:17 GMT -5
Post by Jugglerguy on Jan 17, 2017 14:10:58 GMT -5
Looking good so far. Now get them back in that vibe and finish them up! Is there a reason you did two stages in the rotary? The second stage can be done in a vibe in much less time.
Post by jamesp on Jan 17, 2017 14:28:08 GMT -5
Oh yes, the granite and quartz. Tricky rocks to tumble. Especially that granite.
Very nice.
Post by wigglinrocks on Jan 17, 2017 14:34:28 GMT -5
Nice tumble on a difficult breed of rocks . Which vibe did you go with ?
sdrockgal
Post by sdrockgal on Jan 17, 2017 15:09:28 GMT -5
I didn't own the vibe until I was through stage 2, then I switched them over when I got the vibe.
Post by Jugglerguy on Jan 17, 2017 15:29:02 GMT -5
I didn't own the vibe until I was through stage 2, then I switched them over when I got the vibe. I did the exact same thing.
2nd tumble
Jan 17, 2017 17:36:24 GMT -5
via mobile
Post by pghram on Jan 17, 2017 17:36:24 GMT -5
Excellent results,especially considering the difficulty of the material.
Peace,
Rich
sdrockgal
2nd tumble
Jan 17, 2017 19:10:35 GMT -5
via mobile
Post by sdrockgal on Jan 17, 2017 19:10:35 GMT -5
Looking good so far. Now get them back in that vibe and finish them up! Is there a reason you did two stages in the rotary? The second stage can be done in a vibe in much less time. I threw them back in the vibe for more polish. How long should I put them back for?
sdrockgal
2nd tumble
Jan 17, 2017 19:11:55 GMT -5
via mobile
Post by sdrockgal on Jan 17, 2017 19:11:55 GMT -5
Nice tumble on a difficult breed of rocks . Which vibe did you go with ? A RayTech TV-5. Got it super cheap and figured by the time it breaks down I'll know if I want to invest in a lot-o.
Post by wigglinrocks on Jan 17, 2017 19:26:45 GMT -5
Nice tumble on a difficult breed of rocks . Which vibe did you go with ? A RayTech TV-5. Got it super cheap and figured by the time it breaks down I'll know if I want to invest in a lot-o. Great way to go about the hobby . Lots of people like the lot-o so there will be a lot of help if , when , you go that route .
Post by Jugglerguy on Jan 17, 2017 19:31:41 GMT -5
Looking good so far. Now get them back in that vibe and finish them up! Is there a reason you did two stages in the rotary? The second stage can be done in a vibe in much less time. I threw them back in the vibe for more polish. How long should I put them back for? I just reread your original message. I thought those had only gone through the 500 stage. Now I see that I misread. I usually do two days each in SC 220, AO 500, AO 1000, and AO polish. If you've already done that, they're probably done. A couple days more in polish probably won't hurt anything, but the granite might undercut more. I'm sorry that I didn't read that more carefully.
richardh
Member since June 2016
Post by richardh on Jan 18, 2017 0:04:39 GMT -5
Those came out great. I'm saving for a vib and the TV5 looked interesting. I really want a Lot-o but I'm getting impatient. I'm very interested to hear your thoughts on the TV5 as you get more experience with it.
sdrockgal
Post by sdrockgal on Jan 18, 2017 6:43:34 GMT -5
I threw them back in the vibe for more polish. How long should I put them back for? I just reread your original message. I thought those had only gone through the 500 stage. Now I see that I misread. I usually do two days each in SC 220, AO 500, AO 1000, and AO polish. If you've already done that, they're probably done. A couple days more in polish probably won't hurt anything, but the granite might undercut more. I'm sorry that I didn't read that more carefully. I did the two days each but I'll go one more day and see what happens. I was hoping for a bit more on some of the stones. We will see tonight.
sdrockgal
Post by sdrockgal on Jan 18, 2017 6:45:45 GMT -5
Those came out great. I'm saving for a vib and the TV5 looked interesting. I really want a Lot-o but I'm getting impatient. I'm very interested to hear your thoughts on the TV5 as you get more experience with it. I will let you know after another load or two. The only thing I know for sure is that you can't put anything to big in it. It jams things up and then you get wear marks in the other rocks.
