kenefick
Member since August 2014
Post by kenefick on Jan 31, 2017 12:10:55 GMT -5
I try to make 2 or 3 local craft shows each year to try and recover some of the expense of this hobby. As I get older, I am looking for ways to reduce the physical labor involved in setting up/tearing down. I am thinking of getting some riker mount boxes, so that they can be filled at home, then simply set out on tables. I was looking at the flex-top boxes (plastic instead of glass tops). Any thoughts/advice/experience would be appreciated.
Post by Fossilman on Feb 4, 2017 11:25:43 GMT -5
Sounds like that's the way to go,or just build your own cases out of plywood,with plex glass....
kenefick
Post by kenefick on Feb 6, 2017 8:27:05 GMT -5
Thanks for the response. Not too good with the plywood and plexiglass, so I ordered some of the riker mounts. Bonus is they will be good for storage the rest of the time.
Post by Fossilman on Feb 6, 2017 10:53:25 GMT -5
I also need to buy some riker cases too,starting to teach myself cabbing and need the storage for the better ones...LOL
Don
He wants you too, Malachi.
Member since December 2009
Post by Don on Feb 6, 2017 11:01:29 GMT -5
I find that riker cases are generally bad for long term storage. The paper gets beat up and the glass breaks. plastic craft boxes with the little compartments and a secure lid work much better. just add a little cushion to each compartment with each cab.
Post by Bluesky78987 on Feb 6, 2017 15:53:42 GMT -5
Also riker boxes can't get wet (in case that's a problem at your shows).
Post by parfive on Feb 6, 2017 21:53:22 GMT -5
