Post by parfive on Feb 18, 2017 13:57:24 GMT -5
Post by adam on Feb 18, 2017 15:06:49 GMT -5
I watched a program of the crystal caves on NatGeo yesterday. I thought the crystals were quartz at first but, realized they were too soft to be drilled into, so I knew they had to be gypsum.
Interesting that the bacteria is quite ancient and must use chemosynthesis.
Post by Deleted on Feb 18, 2017 16:09:35 GMT -5
That's really bad ass Rich.
Thanks for sharing.
Do I understand right, that those microbes while "alive" they are in a dormant state and not "living" per se?
Post by Deleted on Feb 18, 2017 16:10:18 GMT -5
I watched a program of the crystal caves on NatGeo yesterday. I thought the crystals were quartz at first but, realized they were too soft to be drilled into, so I knew they had to be gypsum. Interesting that the bacteria is quite ancient and must use chemosynthesis. You came to the correct conclusion, but I have to ask: I can drill quartz. Why can't you?
Post by adam on Feb 18, 2017 16:15:18 GMT -5
The obvious answer: I haven't a drill, shotgunner.
