Post by jamesp on Feb 24, 2017 5:29:01 GMT -5
Replaced the first 303s after 10 years and thousands of cuts. Sped blade rotation speed up for 303s as advised by manufacturer. Like 20% faster rotation than a continuos blade. Running at slow feed speeds this blade cut a 400-800 grit finish for 10 years. Ordered a new one from johnjsgems and got great tips and tech assistance in replacing it. Thank you John. Welded up a spanner wrench. 1.875" stud spacing, two 5/16" X 1/2" long hex bolts with threads hand ground to fit in nut holes. (note sump on right created by 1.5" X 1.5" angle iron laying on bottom full depth where all the mud gets shoveled) Old blade may have more left in it but it started cutting crooked. The cause probably due to the width of the diamonds varying around the circumference and varying left side/right side of blade. No matter, blade cut perfect for 10 years heavy service. Will align carriage parallel to blade before cutting. Increases life of smooth cutting ability of blade. thinner: thicker:
Post by toiv0 on Feb 24, 2017 6:44:27 GMT -5
Maybe you can salvage the diamonds, cut up the blade and throw them into a tumble.....just kidding
Post by toiv0 on Feb 24, 2017 6:46:03 GMT -5
I just replace my 18 inch with a blade from John, it is super sweet and cuts so much better than anything I have used. Thank you John
Post by captbob on Feb 24, 2017 9:08:13 GMT -5
Maybe you can salvage the diamonds, cut up the blade and throw them into a tumble.....just kidding THAT IS FUNNY That old blade deserves a place of honor hanging on a shop wall with a blue ribbon (take one from the dogs) adorning it. I like the sludge sump idea!
Post by jamesp on Feb 24, 2017 9:29:45 GMT -5
Maybe you can salvage the diamonds, cut up the blade and throw them into a tumble.....just kidding THAT IS FUNNY That old blade deserves a place of honor hanging on a shop wall with a blue ribbon (take one from the dogs) adorning it. I like the sludge sump idea! Considering a five gun salute for the funeral of that saw blade. sludge sump: I despise fooling with oil. As long as the bottom of that saw blade is running in clean oil all is well. #1 goal. If your mud is sitting in the bottom of your saw in a separate compartment at a higher elevation the oil will drain out to the 'clean oil blade side'. As the saw runs the vibration causes the wet mud in the mud compartment to settle and compress into a hard paste squeezing out the voids in the sludge that holds oil. After a year that sludge in the right hand compartment can about be peeled up in a one piece rubber-like sheet. The compartment was simply created by a piece of 1.5 inch angle iron cut to exact length front-to-back of saw belly. I will replace it with a 2.5 inch angle iron for deeper capacity next clean out. The mud compartment is 30% of the belly, the clean oil side encompassing the blade is 70%.
Post by johnjsgems on Feb 24, 2017 13:10:08 GMT -5
Thanks all but can't take credit for the blades. They are well made by others.
Post by jamesp on Feb 24, 2017 14:07:06 GMT -5
Thanks all but can't take credit for the blades. They are well made by others. Your thorough advise goes a long way. And those BD blades are worth every penny. Great advise and great choice of product is the other 2/3rds. Salute to johnjsgems !!
Post by toiv0 on Feb 24, 2017 16:03:58 GMT -5
Thanks all but can't take credit for the blades. They are well made by others. Your thorough advise goes a long way. And those BD blades are worth every penny. Great advise and great choice of product is the other 2/3rds. Salute to johnjsgems !! amen! SALUTE
Post by Deleted on Feb 24, 2017 21:19:36 GMT -5
