Post by rockjunquie on Mar 21, 2017 10:39:18 GMT -5
I was thinking about putting some rubber flaps on the wheel cover over the first 2 hard wheels. I think it will help to keep me dry and keep the wheels wetter. Anyone else done this?
Post by johnjsgems on Mar 21, 2017 11:54:57 GMT -5
If you are using their under wheel wetter you should not be throwing water forward. It should be spraying back of hood.
Post by Peruano on Mar 21, 2017 16:26:49 GMT -5
I agree with John, but also would add the perspective that if used, flaps should hang from the front of the shroud to help spread the water, but not touch the wheels. If they touch they potentially can catch grit and "stuff" and continue to smear such "stuff" on your work. Ideally with adequate water your moving the piece back and forth, up and down will spread the water adequately on the wheels.
Post by rockjunquie on Mar 21, 2017 17:03:14 GMT -5
I only get a little spray on the first 2 wheels where it is kicked out from the top of the wheels themselves. I was thinking maybe denim straps, rubber, whatever just to keep the water down. I can't be the only person who has experienced this. I use both geysers under one wheel at a time.
gemfeller
Member since June 2011
Post by gemfeller on Mar 21, 2017 20:19:06 GMT -5
While it's not an elegant fix, I use duct tape attached to the inside of the hood. I use only one under-wheel wetter but it throws more water than stock machines because I have it plumbed to the household water supply. I'm much happier (and dryer!) now. It's easy to adjust the height of the tape to your individual needs. Just clean the inside of the hood first so the tape adheres well.
Post by rockjunquie on Mar 22, 2017 9:38:19 GMT -5
While it's not an elegant fix, I use duct tape attached to the inside of the hood. I use only one under-wheel wetter but it throws more water than stock machines because I have it plumbed to the household water supply. I'm much happier (and dryer!) now. It's easy to adjust the height of the tape to your individual needs. Just clean the inside of the hood first so the tape adheres well. A ha! That's it! I'll try it. Thanks!
Post by roy on Mar 22, 2017 9:41:31 GMT -5
im going to i added fresh water to my titan and genie so i get quite wet
