jennyebert
Member since December 2016
Post by jennyebert on Mar 29, 2017 11:52:02 GMT -5
Hi- Does anyone know of any DIY alternatives to replace the rubber liner for the lid? Thanks!
Post by morerockspleaz on Mar 29, 2017 12:05:02 GMT -5
Is the gasket coming loose from the lid or is it simply deteriorating?
BeLinda
Amazon has this CLEVERBRAND INC. Sponge Neoprene With Adhesive 1/8" Thick X 54" Wide X 2' also has thinner material
Post by MrP on Mar 29, 2017 12:12:47 GMT -5
Yes Don't! Have run for years without...........................MrP
Post by spiceman on Mar 29, 2017 21:54:03 GMT -5
I had my liner get thin. Lowes sells grey plastic sheeting used with PVC applications. It's in that area and sold by the foot, 3 feet wide. Used the metal lid as a template and made my own. A couple bucks. So far about 6 months of tumbling with no sign of wore. When it does wear out I have More material to make more. Worth a try.
jennyebert
Post by jennyebert on Mar 30, 2017 9:46:08 GMT -5
Thanks everyone for replying! I bought a replacement form the rock shed and it lasted only a month before it started thinning out on the edges/ lip of the bowl area and started leaking. I then ordered Sponge Neoprene With Adhesive 1/8" Thick X 54" Wide X 1' from amazon and cut it to size. Worked great for a week or so then totally deteriorated in the same area. Maybe Im doing something wrong? Thanks again for the responses! btw- Im out in Montauk New York love to hear if anyone else is around here :-)
jennyebert
Post by jennyebert on Mar 30, 2017 9:47:49 GMT -5
Is the gasket coming loose from the lid or is it simply deteriorating? BeLinda Amazon has this CLEVERBRAND INC. Sponge Neoprene With Adhesive 1/8" Thick X 54" Wide X 2' also has thinner material Thanks everyone for replying! I bought a replacement form the rock shed and it lasted only a month before it started thinning out on the edges/ lip of the bowl area and started leaking. I then ordered Sponge Neoprene With Adhesive 1/8" Thick X 54" Wide X 1' from amazon and cut it to size. Worked great for a week or so then totally deteriorated in the same area. Maybe Im doing something wrong? Thanks again for the responses! btw- Im out in Montauk New York love to hear if anyone else is around here :-) Read more: forum.rocktumblinghobby.com/thread/78122/thumblers-tumbler-rubber-liner-replacement?page=1#ixzz4cowxPqc5
