AveryLindgren
Member since April 2017
Post by AveryLindgren on Apr 10, 2017 16:55:02 GMT -5
I inherited 2 rock tumbler a with bags of grit
One says 1 pound of 600 And the other says super 10x
What does this mean.
Post by aDave on Apr 10, 2017 17:09:35 GMT -5
I inherited 2 rock tumbler a with bags of grit One says 1 pound of 600 And the other says super 10x What does this mean. 600 is a "fine" grit, and the other is most likely a polish. I found a seller on Ebay who listed its polish as "10x.' Those two levels of grit are for just 2 of the (minimum) 4 that you will need to complete a batch. You still need a coarse and medium. Take a look at the tumbling tutorial which you can get to with this link. It will probably answer or address most of your questions. Regards. Dave
AveryLindgren
Post by AveryLindgren on Apr 10, 2017 17:11:24 GMT -5
I inherited 2 rock tumbler a with bags of grit One says 1 pound of 600 And the other says super 10x What does this mean. 600 is a "fine" grit, and the other is most likely a polish. I found a seller on Ebay who listed its polish as "10x.' Those two levels of polish are just 2 of the minimum 4 that you will need to complete a batch. You still need a coarse and medium. Take a look at the tumbling tutorial which you can get to with this link. It will probably answer or address most of your questions. Regards. Dave I highly appreciate all this info
