AveryLindgren
Member since April 2017
Post by AveryLindgren on Apr 10, 2017 17:22:36 GMT -5
I have a 15 and 2 three pound tumblers,how much grit do i use.
Wooferhound
Lortone QT66 and 3A
Member since December 2016
Post by Wooferhound on Apr 10, 2017 18:41:15 GMT -5
I generally use 1 Tablespoon per pound of rocks in stage 1, 2 and 3, then half of that amount in stage 4 polish.
AveryLindgren
Post by AveryLindgren on Apr 10, 2017 19:07:42 GMT -5
Ok thank you
Post by johnjsgems on Apr 10, 2017 20:01:19 GMT -5
tablespoon per lb. seems standard for rotary tumblers. You can use a little less in the finer (600 and finer) grits like 3/4 tablespoon per. If you have a dedicated polish barrel leave the polish in and keep using it.
AveryLindgren
Post by AveryLindgren on Apr 10, 2017 20:16:11 GMT -5
tablespoon per lb. seems standard for rotary tumblers. You can use a little less in the finer (600 and finer) grits like 3/4 tablespoon per. If you have a dedicated polish barrel leave the polish in and keep using it. If I reserve a barrel for polish and leave it in there,I would get the same results if I switched?
