unclesoska
Member since February 2011
Post by unclesoska on May 3, 2017 20:30:07 GMT -5
gemfeller
Member since June 2011
Post by gemfeller on May 3, 2017 20:37:25 GMT -5
unclesoska, got it! Guess I need to learn my ABC-clamps. I have some but they're made of plastic and I doubt they'd be strong enough to do the job. I'll look around the hardware store next trip. Thanks for the tip and the link.
wampidytoo
Add 5016 to my post count.
Member since June 2013
Post by wampidytoo on May 4, 2017 4:32:56 GMT -5
I made a few of those after you posted it and I really like the look of them. I mostly give instead of sell so I got into the lazy habit of glue on's to save time. Do you have a method of cleaning the drillings out of the hole so the pin doesn't pull out? One of the problems I had with those. Jim
wampidytoo
Post by wampidytoo on May 4, 2017 4:46:30 GMT -5
Neat techniques melhill1659 and wampidytoo . Since I work with small pieces only the Jet Sett approach is more my style than the big industrial method but both have their uses. I'll give it a try soon though I'm pleased with the way my own method is developing. I can see where the Jet Sett method would work better for oddly-shaped pieces and I have a couple of those to drill. What's the material in the lovely finished piece you posted melhill1659 ? I experimented more today with the side-drilling technique I posted about yesterday. Today’s project went smoothly due to some tinkering with my equipment. I padded my mini-vise jaws with some of the rubbery tape they use for refrigerator magnets to prevent slippage of the workpiece. And I found a plastic container with a nice flat bottom to hold the vise and workpiece while immersed in water. The tuna can I used before had a ribbed bottom that flexed and messed up alignment when drill pressure was applied. The new arrangement worked flawlessly. I used a small piece of the Californite slab left from the previous project to make a double-sided pendant. The entire project (equipment modification, sawing, preforming, drilling, cabbing and polishing) took a little less than 90 minutes. Of course future projects with harder materials will probably take longer. Anyhow, here’s the result: Overall View Side View Face 1 Face 2 Looks like you definitely have things under control there. Sweet cab/focal bead and the hole looks flawless on the outside. I went big because it was what I had at the time. If I ever go back to cabbing and need a side hole I am quite sure I would step down and use the smaller tools that I now have. Pulling the drill press vice out of the water to reverse or change the cab can soak up a lot of towels in a hurry.
Post by melhill1659 on May 4, 2017 6:18:52 GMT -5
Neat techniques melhill1659 and wampidytoo . Since I work with small pieces only the Jet Sett approach is more my style than the big industrial method but both have their uses. I'll give it a try soon though I'm pleased with the way my own method is developing. I can see where the Jet Sett method would work better for oddly-shaped pieces and I have a couple of those to drill. What's the material in the lovely finished piece you posted melhill1659 ? I experimented more today with the side-drilling technique I posted about yesterday. Today’s project went smoothly due to some tinkering with my equipment. I padded my mini-vise jaws with some of the rubbery tape they use for refrigerator magnets to prevent slippage of the workpiece. And I found a plastic container with a nice flat bottom to hold the vise and workpiece while immersed in water. The tuna can I used before had a ribbed bottom that flexed and messed up alignment when drill pressure was applied. The new arrangement worked flawlessly. I used a small piece of the Californite slab left from the previous project to make a double-sided pendant. The entire project (equipment modification, sawing, preforming, drilling, cabbing and polishing) took a little less than 90 minutes. Of course future projects with harder materials will probably take longer. Anyhow, here’s the result: Overall View Side View Face 1 Face 2 That's beautiful! Yeah you noticed that awesome raw cut piece huh 😂 I was just experimenting. Seems you got it though!! The mold really is simple and cheap to make. No clamps needed and is moldable to any shape. It's 100% silicone caulk, cornstarch an a drop of baby oil.
unclesoska
Post by unclesoska on May 4, 2017 8:30:23 GMT -5
I made a few of those after you posted it and I really like the look of them. I mostly give instead of sell so I got into the lazy habit of glue on's to save time. Do you have a method of cleaning the drillings out of the hole so the pin doesn't pull out? One of the problems I had with those. Jim Drilling under water and pulsing the drill up and down should keep the hole cleared out
gemfeller
Post by gemfeller on May 4, 2017 12:25:30 GMT -5
[quote author=" wampidytoo" source="/post/924383/thread" timestamp="1493890376 Do you have a method of cleaning the drillings out of the hole so the pin doesn't pull out? One of the problems I had with those. Jim[/quote] If I understand your question/problem correctly, I think an ultrasonic would do the job.
wampidytoo
Post by wampidytoo on May 5, 2017 3:20:51 GMT -5
[quote author=" wampidytoo" source="/post/924383/thread" timestamp="1493890376 Do you have a method of cleaning the drillings out of the hole so the pin doesn't pull out? One of the problems I had with those. Jim If I understand your question/problem correctly, I think an ultrasonic would do the job. [/quote] Wow, you made my day. Not sure why that did not cross my mind because I have a small ultrasonic jewelry cleaner that i have used quite a bit and my son has a very large one for his tattoo equipment. Set them in the basket up-side-down and shake them for a couple of minutes. Doesn't get any easier than that. Jim
gemfeller
Post by gemfeller on May 5, 2017 17:50:09 GMT -5
I'm very happy with my new side-drilling method described upthread, and I want to do some beads/pendants with standard-thickness slabs (about 6 mm or 1/4-inch). My first one, below, was made with Mary Ellen jasper I received Wednesday from Billy. Thank you Billy, very nice material. Drilling took a little longer than with the Californite due to the hardness difference but it went pretty fast (about 8-10 minutes). The hole is 2.5 mm. My wife now has accent pendants in green and red/orange and I know she'll be asking for more colors. Good practice for me! Mary Ellen Pendant/Focal Bead Wider View
Post by pghram on May 6, 2017 17:49:10 GMT -5
Well done, that looks great.
Peace,
Rich
