Post by toiv0 on Apr 25, 2017 14:00:18 GMT -5
Want to use up all my diamond on the old 80 grit hard wheel. Is there a way to dress it and expose what is left of the diamond?
Post by rockjunquie on Apr 25, 2017 17:02:18 GMT -5
You can turn it around and you can use a dressing stick. I do.
Post by toiv0 on Apr 25, 2017 17:51:35 GMT -5
Is this the dressing stick. Says it for corundum and silicon carbide
Post by wigglinrocks on Apr 25, 2017 18:06:49 GMT -5
Post by toiv0 on Apr 25, 2017 18:38:44 GMT -5
Make more sense than wheel. Wonder if a fire brick or old stone wheel would do the same.
Post by wigglinrocks on Apr 25, 2017 18:48:01 GMT -5
Make more sense than wheel. Wonder if a fire brick or old stone wheel would do the same. I really don't see why it wouldn't work . But I don't have a cab machine . They also have a T-shaped wheel dresser . I would try a brick or a wheel , not out anything .
Post by Tommy on Apr 28, 2017 9:56:27 GMT -5
Want to use up all my diamond on the old 80 grit hard wheel. Is there a way to dress it and expose what is left of the diamond? Billy is this a Galaxy wheel on your Genie? I'm sure you know those are only coated - they can't take a lot of scraping or you'll take the diamond layer right off. The Kingsley dressing stick is your best bet - with a very light touch.
Post by johnjsgems on May 1, 2017 12:40:11 GMT -5
What Tommy said. When you get down to shiny smooth steel there is no more nickle/diamond layer left. If the wheel is glazed over you may improve with dressing or turning around.
