Post by toiv0 on Apr 27, 2017 14:08:30 GMT -5
Post by wigglinrocks on Apr 27, 2017 20:27:00 GMT -5
That stuff sure has a flash but has to be cut right to get the most flash . Reminds me , gotta go get me some WI moonstone , with the blue flash .
Post by toiv0 on Apr 28, 2017 7:37:55 GMT -5
I believe Moonstones are feldspar and need to be oriented to get the flash.
pizzij
Member since November 2009
Post by pizzij on Apr 28, 2017 7:44:03 GMT -5
Hmmm...do we have any collectors of Binghamite here? Saw amazing chatoyant slabs in various rock shops when I was there in 2003. Regret not buying some.
Post by orrum on Apr 28, 2017 8:33:01 GMT -5
Ok somebody tell us about orienting and cabbing moonstone???
Post by Bluesky78987 on Apr 28, 2017 10:13:36 GMT -5
I have a slab of I think Virginia moonstone (pale grey with very strong white flash). It seemed to be cut like you would cut labradorite or obsidian. Orient stone so it is flashing you as strongly as possible, then cut perpindicular to that. I made one little cab from it and it came out fine with a normal dome. The piece toiv0 posted is much prettier with the color though.
Post by wigglinrocks on Apr 28, 2017 11:27:06 GMT -5
I have a slab of I think Virginia moonstone (pale grey with very strong white flash). It seemed to be cut like you would cut labradorite or obsidian. Orient stone so it is flashing you as strongly as possible, then cut perpindicular to that. I made one little cab from it and it came out fine with a normal dome. The piece toiv0 posted is much prettier with the color though. Perfect explanation .
Post by Bluesky78987 on Apr 28, 2017 13:08:37 GMT -5
Oh I forgot. Stand so that the sun is shining over your shoulder onto the rock.
Post by toiv0 on Apr 28, 2017 13:51:57 GMT -5
I have a light that shines into a mirror box set at a 45 degree angle. Hole at the top you can look through for orientation.
micellular
Rock fever is curable with more rocks.
Member since September 2015
Post by micellular on Apr 28, 2017 15:24:36 GMT -5
oooooohhh
