stacker
Member since May 2017
Post by stacker on May 29, 2017 7:19:29 GMT -5
My motor temp is running 134 deg f. On the single loto. i also have a fan on it to try to cool it down more. I have it mounted to two cement blocks. when I run it I always fill it up with in one inch from the top.
what temperature are you guys seeing?
Wooferhound
Lortone QT66 and 3A
Member since December 2016
Post by Wooferhound on May 29, 2017 8:07:20 GMT -5
Mine run too hot to hold my finger on it for more than a few seconds
stacker
Post by stacker on May 29, 2017 8:30:14 GMT -5
Thanks didn't know if I was the only one. Or if I had an issue with the motor.
lookatthat
Post by lookatthat on May 29, 2017 8:42:48 GMT -5
My 3A is not running that hot, I can hold my hand on the motor casing. But it's only about 60 degrees where I have (today anyway)and I don't have it loaded quite that much.
Wooferhound
Lortone QT66 and 3A
Post by Wooferhound on May 29, 2017 8:52:29 GMT -5
I have had my 3A with the case off to lube it and look at the belt. Checked the motor while I was in there and thought it ran just as hot as the QT66.
Wooferhound
Lortone QT66 and 3A
Post by Wooferhound on May 29, 2017 17:31:48 GMT -5
Noticed that my Lortone 3A had 16 air exhaust holes and just 8 holes on the intake in front of the fan. I thought it was running a little warm on the case so I got some wirecutters and cut out between all the intake holes making one giant hole for the fan to pull air from. I think it is running cooler now. First attempt to post a photo using RockShow photo hosting
Post by aDave on May 29, 2017 17:48:58 GMT -5
Good info guys, but the OP is asking about his Loto vibe tumbler. Sorry OP, I can't help you, as I don't own one. Dave
Wooferhound
Lortone QT66 and 3A
Post by Wooferhound on May 29, 2017 18:20:59 GMT -5
Gosh, you are so correct , I thought I saw the Lortone name in there. I just turned 60 and it is already starting to show... But the test of the RockShow picture hosting worked perfectly
Post by aDave on May 29, 2017 18:24:30 GMT -5
Gosh, you are so correct , I thought I saw the Lortone name in there. I just turned 60 and it is already starting to show... I'm right behind you, brother! Dave
stacker
Post by stacker on May 29, 2017 18:30:39 GMT -5
No problem guys, this is all good info.
Post by aDave on May 29, 2017 18:38:12 GMT -5
No problem guys, this is all good info. There are a pretty fair amount of Loto users here, so I'm sure someone will eventually jump in. Must be the holiday. melhill1659Garage RockerJugglerguyDave
Post by Jugglerguy on May 29, 2017 18:40:29 GMT -5
My Lot-O is off right now, and I don't have a really good way to measure the temperature of it.
Post by coloradocliff on May 29, 2017 19:10:39 GMT -5
Stacker.. Ditto Jugglers words. My loto runs hot like all continuous service motors. I probably have own 60-70 motors running as I type for a large nursery and never had a fire in all the time I have operated. They get hot, bearing drag, make some noise, then trip out. try em again for a few days and then replace motor. If it seizes it seizes and trips the break. New motor but cant worry about maybes. Might look at lubing it occasionally.
dave496
Member since December 2010
Post by dave496 on May 29, 2017 22:30:28 GMT -5
Single lot-o, on the back cylindrical surface the average temp is around 130f with ambient temp in the 80's. Checking various places on the motor the temp ranged from 110 to 140. This unit is less than a year old, mounted on one block, occasional use.
Post by spiceman on May 29, 2017 22:44:50 GMT -5
I have recently bought a lotto but have no good way to measure temp.. After running it for days and mounted to a block my motor gets hot but I can still touch it. It is warmer than my tumbler motor. I don't have a thermo couple. (Spelling)
Post by broseph82 on Jun 3, 2017 9:27:41 GMT -5
Single lot-o, on the back cylindrical surface the average temp is around 130f with ambient temp in the 80's. Checking various places on the motor the temp ranged from 110 to 140. This unit is less than a year old, mounted on one block, occasional use. Call Shawn at the RockShed and ask. Please don't flame if I spelled his name wrong.
