Post by Rockoonz on Aug 15, 2017 13:39:29 GMT -5
jamesp I bet you know all about these... I have a Viking vibe unit that came in an estate. It's the one with 2 hoppers, maybe 4 or 5 lb each. Former owner tried to put a larger thumler barrel on it, of course unsuccessfully. All the original parts were with it so I have assembled. When I turned it on it seemed to be too aggressive. Looked at the weight sets on the shaft, one was at about 3.5, the other 2.5. I moved the 3.5 end to 2. Needed a couple mounting bolts for the hoppers so I haven't fired it up, will the settings I have work o.k.? Secondly, what's it worth if I decide to sell it?
Post by Deleted on Aug 15, 2017 14:27:31 GMT -5
Have you run it with full barrels?
Post by jamesp on Aug 15, 2017 16:11:49 GMT -5
jamesp I bet you know all about these... I have a Viking vibe unit that came in an estate. It's the one with 2 hoppers, maybe 4 or 5 lb each. Former owner tried to put a larger thumler barrel on it, of course unsuccessfully. All the original parts were with it so I have assembled. When I turned it on it seemed to be too aggressive. Looked at the weight sets on the shaft, one was at about 3.5, the other 2.5. I moved the 3.5 end to 2. Needed a couple mounting bolts for the hoppers so I haven't fired it up, will the settings I have work o.k.? Secondly, what's it worth if I decide to sell it? As far as selling it I am not sure. Mine for $150, but it was an inherited unwanted devise. I would think $300-500. Settings for 35 pound hopper should be 2.5 to 3.5. settings for 14 should be about 1.0 to 1.2, barely off balance. The little 5-6's probably less, I think you can do .8. And they are designed to be run full so be sure to have hoppers on it and full of rocks. Hope this helps. Some Vsonic photos www.flickr.com/photos/67205364@N06/sets/72157649367092502
Post by Rockoonz on Aug 15, 2017 16:54:05 GMT -5
Thanks, I'll dial it down a bit before I try it.
Post by MrP on Aug 15, 2017 17:57:33 GMT -5
jamesp I bet you know all about these... I have a Viking vibe unit that came in an estate. It's the one with 2 hoppers, maybe 4 or 5 lb each. Former owner tried to put a larger thumler barrel on it, of course unsuccessfully. All the original parts were with it so I have assembled. When I turned it on it seemed to be too aggressive. Looked at the weight sets on the shaft, one was at about 3.5, the other 2.5. I moved the 3.5 end to 2. Needed a couple mounting bolts for the hoppers so I haven't fired it up, will the settings I have work o.k.? Secondly, what's it worth if I decide to sell it? I am not jamesp but I also have one. Make sure the bolts are grade 8 and the buckets are bolted down tight. If they come loose you will break an ear off of the bowl. My unit came set up that way so I made a 40lb tub out of a propane tank. Works great. If you ran it with no weight on it you will not be able to how it is working. Need weight to get it to vibe right............................MrP
