Thunderthud
Member since November 2017
Post by Thunderthud on Nov 30, 2017 15:16:08 GMT -5
Ok, I was wanting to change out a bump drum to an expando. Not sure how to do this? The bump wheels have a set screw to attach to the 1" shaft. Don't have the expando drum yet, but from what I can see from pics, there would not be a set screw. Thoughts? Thank you! Tom
zarguy
Member since December 2005
Post by zarguy on Nov 30, 2017 16:45:23 GMT -5
minerken
Member since August 2013
Post by minerken on Nov 30, 2017 17:44:01 GMT -5
I have had good luck using shaft collars glued to the wheel on one or both sides.
Post by johnjsgems on Nov 30, 2017 18:16:28 GMT -5
Expandos mount like other wheels by tightening end nut. If you cut spacers (expando hub centers are only 1/2" thick) be sure to cut them square. I use 1" schedule 40 PVC pipe and cut with a tiny chop saw.
Thunderthud
Post by Thunderthud on Dec 1, 2017 7:27:19 GMT -5
Thanks guys! Think I will try glueing the lock collars on. There are no threads on the shaft. Tom
Post by Peruano on Dec 1, 2017 8:31:16 GMT -5
You may be using the bump wheel end of an old HP arbor which does not have threads. Shaft collars will work, but obviously they have to be tight. I have done this but didn't think about adding glue to the mix. Locktite might be one alternative.
Post by johnjsgems on Dec 7, 2017 21:43:59 GMT -5
If shaft was smaller you could by a shaft adapter.
