Post by jamesp on Dec 3, 2017 8:55:59 GMT -5
Got a killer polish on the flat faces. But the edges are frosted with about a 500 grit finish. Attributing frosted edges to running it with bigger rocks in the vibe. A good candidate for small media only-small pieces of fluorite only, and no larger rocks in the batch whatsoever.
Post by Jugglerguy on Dec 3, 2017 9:27:25 GMT -5
What was your method? I’d love to be able to shine that stuff up.
Post by jamesp on Dec 3, 2017 12:58:39 GMT -5
What was your method? I’d love to be able to shine that stuff up. Probably need your Lot-O for the AO 220 and AO 14,000 steps but I would do a normal rotary tumble to shape. AO 220 for 2 days. Watch for quick mud build up. AO 14,000 for 1 day I used small polished agate media(1/2" and smaller) Rob, not sure about ceramic media. Fluorite 1 inch and smaller for first load. Suggest 50 to 60% media. The Lot-O should do well with the AO 220. Cheap fused AO 220 from Ebay will do. I bought 10 pounds for about $25 and I'll never use it up. www.ebay.com/itm/10-LBS-White-Fused-Alumina-Aluminum-Oxide-220-Grit-Sand-Blasting/111849277529?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649ETA Try to get fluorite without fractures. Not easy to find and not cheap. Small crystals would be best for quality.
Post by Jugglerguy on Dec 3, 2017 18:14:32 GMT -5
I’m surprised that you went from 220 right to polish. I’ll have to give it a try.
Post by jamesp on Dec 3, 2017 18:44:04 GMT -5
I’m surprised that you went from 220 right to polish. I’ll have to give it a try. Aluminum oxide 220, important
Post by Jugglerguy on Dec 3, 2017 18:47:40 GMT -5
I’m surprised that you went from 220 right to polish. I’ll have to give it a try. Aluminum oxide 220, important Oh, I'm glad you said something. I always use silicon carbide 220. I completely missed that you aren't using that.
Post by jamesp on Dec 3, 2017 20:01:32 GMT -5
Aluminum oxide 220, important Oh, I'm glad you said something. I always use silicon carbide 220. I completely missed that you aren't using that. AO 500 will give you a polish in the Lot-O. AO 220 probably will too.
