Post by jamesp on Dec 15, 2017 6:35:21 GMT -5
This is a 6 inch diameter ball mill. Filled less than a rock tumbler but similar action. Filled with 3/8" balls for grinding glass. Lyrics by Steppenwolf JR lol. Good representation of the action of a rotary tumbler at higher speeds. See 85 RPM action at 55 seconds. - approaching maximum for rock tumbler See 113 RPM action at 138 seconds - too fast Good reason why not to run a rotary above 85 RPM. Unless you have a bit of a thick slurry; but if your slurry gets thin you may beat your rocks up. From 3:13 to 3:40 the barrel is turning at 85 RPM and it can be seen that the theory that hard barrels crushes grit faster is laughable. There is little movement or impact against the barrel wall. The abrasive gets crushed in the layer below the avalanche on top layer. Thats where the rock grinding takes place. Area 2 is where the most intense grinding happens, Area 1 (top) is next. The least grinding is the bottom area 3: If you want to grind rocks fast without damage the barrel should run about 75 RPM max. with a slurry for safe keeping. Then 25 to 30 RPM with say SiC 30 -80 for a week to 10 days. (all speeds for a 6 inch barrel) Cut speed by ratio of barrel diameter increase. To prep rocks for vibe or 220 step in rotary. I used this video a long time ago to get an idea of how my 6" PVC barrels function. I have run my 6 inch barrels at 70 RPM. Problem with that is you have to add coarse SiC every day. Too much work. Using bulk SiC I may go back to 65 to 70 RPM since it time releases basically. If in a hurry to coarse grind.
Post by Garage Rocker on Dec 15, 2017 8:34:26 GMT -5
From 3:13 to 3:40 the barrel is turning at 85 RPM and it can be seen that the theory that hard barrels crushes grit faster is laughable. There is little movement or impact against the barrel wall. Well OK, you're the expert. A simple guy like me might ask, then why do your barrels wear so fast with super course grit? And why are you trying to build an indestructible barrel?
Post by Garage Rocker on Dec 15, 2017 8:44:11 GMT -5
Nice music on the vid. My mom's favorite song.
Post by jamesp on Dec 15, 2017 9:02:04 GMT -5
Nice music on the vid. My mom's favorite song. That is some raw schnitt. Fits the grind.
Post by jamesp on Dec 15, 2017 9:09:04 GMT -5
From 3:13 to 3:40 the barrel is turning at 85 RPM and it can be seen that the theory that hard barrels crushes grit faster is laughable. There is little movement or impact against the barrel wall. Well OK, you're the expert. A simple guy like me might ask, then why do your barrels wear so fast with super course grit? And why are you trying to build an indestructible barrel? Sure there is some effect. Keep in mind the poor barrel is 24/7. Appears the grit is having it's way with the barrel more than the barrel having it's way with the grit. Do you have a Lortone or a Thumler ? Need to know on behalf of science. What would your Mom say about that music ? You were joking I presume ? My Mom was a sweet Christian lady but loved Lynyrd Skynrd lol.
Post by Drummond Island Rocks on Dec 15, 2017 9:14:37 GMT -5
When I listen to German hard rock I prefer Rammstein.
Post by Garage Rocker on Dec 15, 2017 9:15:53 GMT -5
Well OK, you're the expert. A simple guy like me might ask, then why do your barrels wear so fast with super course grit? And why are you trying to build an indestructible barrel? Sure there is some effect. Keep in mind the poor barrel is 24/7. Appears the grit is having it's way with the barrel more than the barrel having it's way with the grit. Do you have a Lortone or a Thumler ? Need to know on behalf of science. What would your Mom say about that music ? You were joking I presume ? My Mom was a sweet Christian lady but loved Lynyrd Skynrd lol. No way, we used to listen to that song at Christmas time. I use only Lortone tumblers. Remember, use little words if talking science, you have a light bulb with your avatar and I have a piece of pie.
Post by jamesp on Dec 15, 2017 9:47:25 GMT -5
When I listen to German hard rock I prefer Rammstein. Chuck Why do those German folks sound so guttural and dastardly ? Their sound rooms must require 3 inch steel walls. Strong music Chuck.
Post by jamesp on Dec 15, 2017 9:50:17 GMT -5
Sure there is some effect. Keep in mind the poor barrel is 24/7. Appears the grit is having it's way with the barrel more than the barrel having it's way with the grit. Do you have a Lortone or a Thumler ? Need to know on behalf of science. What would your Mom say about that music ? You were joking I presume ? My Mom was a sweet Christian lady but loved Lynyrd Skynrd lol. No way, we used to listen to that song at Christmas time. I use only Lortone tumblers. Remember, use little words if talking science, you have a light bulb with your avatar and I have a piece of pie. I gave that pie off ? Why do you have it now ? That's not fair. Well, come to think of it, someone gave it to me and I handed it off.... Next science question, how many RPM is your Lortone ?
Post by Drummond Island Rocks on Dec 15, 2017 9:54:20 GMT -5
When I listen to German hard rock I prefer Rammstein. Chuck Why do those German folks sound so guttural and dastardly ? Their sound rooms must require 3 inch steel walls. Strong music Chuck. I have music on at work every day for 10 hours a day so I listen to any and all types of music. I think Jazz and classical are the only two that don't make the cut. Internet radio opens up a whole lot of radio station options. Chuck
Post by Garage Rocker on Dec 15, 2017 10:00:49 GMT -5
No way, we used to listen to that song at Christmas time. I use only Lortone tumblers. Remember, use little words if talking science, you have a light bulb with your avatar and I have a piece of pie. Next science question, how many RPM is your Lortone ? Don't know, never been that bored. It just works. Good enough for me. I'm sure someone out there knows.
Post by Garage Rocker on Dec 15, 2017 10:03:32 GMT -5
Full disclosure: I never questioned how my TV or microwave work either. But I do like pie.
Post by Drummond Island Rocks on Dec 15, 2017 11:00:24 GMT -5
Been awhile since I have timed my lortones but that is how I set up my homemade tumbler. I matched the lortone speed. Left all the technical stuff to the pros. Seems like the 3 pound barrels were about 42 rpm and the 6 and 12 pound barrels were around 30 rpm.
Post by captbob on Dec 15, 2017 17:07:34 GMT -5
Post by jamesp on Dec 15, 2017 22:32:08 GMT -5
I got 2 of those barrels when I started tumbling. The photo below is it after 2 months running, those are hard SDR thin wall PVC. That guy is a crook and someone needs to choke his drawers full of schnit. Yep. I could build barrels for resale out of this heavy duty black plastic. Guess what, they would buy the $48 unit instead of a $100 black pipe unit that I made that lasts a lifetime. My interest is using cheap time release bulk grit and faster running barrels. I tumble 4 cheap. And fast. And hassle free. But I will need those heavy black barrels to stand up to the bulk grit. So today I went to the big industrial distributor. This one will be built in 20 minutes, 2 fittings requiring one weld and cut snout shorter. 8.5 inch pipe, 9/16" wall thickness. I have a couple of other alternate designs. They wouldn't be resold for $48. They will take care of jamesp's needs. $48 jamesp
Post by jamesp on Dec 15, 2017 22:53:09 GMT -5
Full disclosure: I never questioned how my TV or microwave work either. But I do like pie. I hope your microwave is big enough to heat your apple pie.
Post by HankRocks on Dec 15, 2017 22:54:36 GMT -5
Caveat Emptor! Capies ut pendes(I think?)
Post by jamesp on Dec 15, 2017 22:55:42 GMT -5
Been awhile since I have timed my lortones but that is how I set up my homemade tumbler. I matched the lortone speed. Left all the technical stuff to the pros. Seems like the 3 pound barrels were about 42 rpm and the 6 and 12 pound barrels were around 30 rpm. Chuck Makes perfect sense.
Post by jamesp on Dec 15, 2017 22:57:44 GMT -5
Caveat Emptor! Capies ut pendes(I think?) Yep, snakes like that can get away with screwing unknowing people.
Post by captbob on Dec 15, 2017 23:26:31 GMT -5
opening size?
