Post by broseph82 on Dec 20, 2017 16:46:11 GMT -5
And what I mean by that is the type of foam used, and how the grit “paper/tape” is adhered to it? I had a wheel break down prematurely once and saw what seemed to be stitches (east wind lapidary) holding the grit tape to the foam. .
I have an idea and if anyone has any links or helpful info it would be much appreciated. Thank You!
If I can figure it out I’ll be glad to share the process once it’s said and done
Post by vegasjames on Dec 20, 2017 19:12:24 GMT -5
I repaired some wheels with some belts for the expando drums. I just carefully peeled off the old belt then wet the foam, spread some Gorilla glue (polyurethane) over the wheel then slide the new belt on and let it set up. The moisture expands the polyurethane as it sets filling holes in the foam and holding the belt on tight.
Post by johnjsgems on Dec 27, 2017 15:50:20 GMT -5
At Diamond Pacific they glue a seamless belt (most expensive part of a Nova) over the foam. Then with a paint brush they smear on the diamond in goop (magic goop they worked on for years to get right) in a dust free room. None of the do it yourself or commercial recoats ever "feel" like a real Nova but you can load a lot more diamond on. I had some Chinese Eastwind knockoffs that were just diamond belts glued to a foam lined wheel.
Post by toiv0 on Mar 11, 2018 7:17:05 GMT -5
I just had a belt release on my Genie, kind of pushed it back on and still using it though it feels a little out of round. maybe i will glue it.
Post by johnjsgems on Mar 15, 2018 10:41:38 GMT -5
If you wanted to call them they would exchange that wheel for you. They switched to a more environmentally friendly adhesive some time ago and had an employee that was not very motivated for a while. I exchanged a wheel at a show for a customer and when I took it to DP they looked and said there was no glue under the belt. Stuff happens but they are very good at standing by their wheels.
