Post by toiv0 on Dec 30, 2017 20:21:56 GMT -5
First few. ![](https://uploads.tapatalk-cdn.com/20171231/7df34c95502a8d1c1c33326f36e9a543.jpg)
NDK
Post by NDK on Jan 1, 2018 13:50:55 GMT -5
Interesting way to make them Billy. Very uniform. Nicely done.
Post by accidentalrockhound on Jan 2, 2018 17:16:02 GMT -5
Nice what gauge is that wire you use? Do you use them like that or do you cut them?
Post by toiv0 on Jan 2, 2018 18:33:51 GMT -5
Nice what gauge is that wire you use? Do you use them like that or do you cut them? I had made one out of crazy 8 ring shank and didn't like it at first, it is on the Tiger eye ring. These are 10 ga half round which is about right for most rings.
Post by toiv0 on Jan 2, 2018 18:38:15 GMT -5
Crazy 8 ring shank on the ring ![](https://uploads.tapatalk-cdn.com/20180102/b4d72e43e82ebf16ab0ab4e4ba5e960d.jpg) ![](https://uploads.tapatalk-cdn.com/20180102/30012b4739bb82397a29b24e5206a090.jpg)
Post by toiv0 on Jan 4, 2018 6:36:04 GMT -5
Nice what gauge is that wire you use? Do you use them like that or do you cut them? Didn't register the second half of question. I flatten the top and just solder on like that. If I do a open shank I will saw the wire in two, Might try to cut them and see how they look.
Post by toiv0 on Jan 4, 2018 6:38:34 GMT -5
Interesting way to make them Billy. Very uniform. Nicely done. Took me a few to get it down, haven't quite figured out the sizing. I had to size the Tiger eye ring down after I made it.
Post by accidentalrockhound on Jan 7, 2018 17:19:41 GMT -5
Nice what gauge is that wire you use? Do you use them like that or do you cut them? Didn't register the second half of question. I flatten the top and just solder on like that. If I do a open shank I will saw the wire in two, Might try to cut them and see how they look. Iam sure these ring shanks can be used as is or cut to accommodate different sizes .do you shape them on a ring mandrel? o
Post by toiv0 on Jan 7, 2018 19:51:12 GMT -5
Didn't register the second half of question. I flatten the top and just solder on like that. If I do a open shank I will saw the wire in two, Might try to cut them and see how they look. Iam sure these ring shanks can be used as is or cut to accommodate different sizes .do you shape them on a ring mandrel? o Anything round will shape them. Just wrap around. Haven't quite figured out how to get an exact size. But doesn't really matter if your making for stock, but for an order I have had to re size.
Post by Deleted on Jan 8, 2018 0:09:07 GMT -5
You are not fire! 🔥
