Flint?
Jan 2, 2018 8:29:29 GMT -5
Post by grumpybill on Jan 2, 2018 8:29:29 GMT -5
Contents of a bag of "Tumbling Mix" I got for Xmas. To my inexperienced eye, it looks like waste from flint knapping. Am I right that it's flint?
Flint?
Jan 2, 2018 9:23:30 GMT -5
Post by Jugglerguy on Jan 2, 2018 9:23:30 GMT -5
Contents of a bag of "Tumbling Mix" I got for Xmas. To my inexperienced eye, it looks like waste from flint knapping. Am I right that it's flint? I’m not sure if it’s flint, but if it is, it should tumble well.
Flint?
Jan 2, 2018 10:38:57 GMT -5
Post by grumpybill on Jan 2, 2018 10:38:57 GMT -5
I've been disappointed with tumbling thin little chips. Most of these are 1/4" or less thick, tapering to nothing. I suspect there'll be very little left after the sharp edges round off.
Post by rmf on Jan 2, 2018 12:05:40 GMT -5
yes those look like flint/chert from knapping. there are a couple of black ones that may be obsidian but can't tell for sure from the pic
Flint?
Jan 2, 2018 12:23:12 GMT -5
Post by grumpybill on Jan 2, 2018 12:23:12 GMT -5
No obsidian in the mix.
Post by Deleted on Jan 2, 2018 13:06:19 GMT -5
There is even a arrowhead in the mix, tip broken off. Lower right 4oclock
Flint?
Jan 2, 2018 14:31:43 GMT -5
Post by grumpybill on Jan 2, 2018 14:31:43 GMT -5
Not sure if it is a failed arrowhead, but that would support my suspicion that the stones are knapping waste.
Post by RickB on Jan 2, 2018 15:18:25 GMT -5
That definitely looks like flint knapping debitage to me. I too see a knapped point missing a tip, lower right about three up. Brown and has been punch notched on both sides. Rick B
Flint?
Jan 2, 2018 19:13:21 GMT -5
Post by fernwood on Jan 2, 2018 19:13:21 GMT -5
A lot depends on how you tumble. Rotary or vibe. I could see these working in a vibe. Yes, agree on the arrowhead mishap.
Post by grumpybill on Jan 2, 2018 19:57:12 GMT -5
A lot depends on how you tumble. Rotary or vibe. I could see these working in a vibe. Yes, agree on the arrowhead mishap. Haven't decided how to do them. Probably a short run of course in a rotary to take the sharp edges off, then move to a Lot-0? Not enough of them to run by themselves. Will need to add them to something else. Unless I go all rotary in one of my little 1.5lb barrels... Any advice would be greatly appreciated.
