Post by Deleted on Feb 22, 2018 20:20:29 GMT -5
Some nice end cuts 1 week in checking for broken soldiers
unclesoska
Member since February 2011
Post by unclesoska on Feb 22, 2018 20:37:24 GMT -5
Those are shaping up nicely. Just thinkin' out load here, if you notice any pieces that have a fracture that could break, sometimes it's best to pull them before they break, as the broken sharp edges will scratch the good pieces, sometimes making it necessary to repeat the coarse stage.
Post by Deleted on Feb 22, 2018 20:39:39 GMT -5
Those are shaping up nicely. Just thinkin' out load here, if you notice any pieces that have a fracture that could break, sometimes it's best to pull them before they break, as the broken sharp edges will scratch the good pieces, sometimes making it necessary to repeat the coarse stage. Thanks, will take that advice thank you
Post by Jugglerguy on Feb 22, 2018 20:40:37 GMT -5
Those are shaping up nicely. Just thinkin' out load here, if you notice any pieces that have a fracture that could break, sometimes it's best to pull them before they break, as the broken sharp edges will scratch the good pieces, sometimes making it necessary to repeat the coarse stage. Yep, I break them on purpose because I don’t really like fractures in my finished rocks anyhow. I find that the sharp edges on end cuts round off at a frustratingly slow rate.
Post by Fossilman on Feb 23, 2018 10:22:54 GMT -5
Going to be some nice pieces when finished.....
Post by pauls on Feb 23, 2018 15:11:38 GMT -5
I find with the flats that you I need to grind the edges round first, because they're flat they tend to slide flat and grind the flat sides thinner without doing a lot to the corners and edges.
I agree about giving them a tap with a hammer to break them along cracks, anything in my tumbler with holes or cracks get tossed or gets more grinding or sawing to eliminate the blemish.
