anubis63
Member since February 2018
Post by anubis63 on Mar 5, 2018 9:19:45 GMT -5
I've been running my tumblers, 8 barrels in all, and with my harder stones I've been tumbling a month on stage one. I know stage two is to smooth out the scratches but do I need to run it a month or will two weeks do on the other three stages? Also I haven't oiled my tumblers except on the shaft that turns the barrels. Where else would I oil? I had a bad experience on my first tumbler the first day I got it I had oiled the shaft with WD40 and it got under the rubber that the barrel rolls on so it slipped and I had to take it apart, slide the rubber off and thoroughly clean it and I don't want to make that mistake again. So my two questions "how long on stage two, three, and four" and "where to oil the tumbler".
Post by gmitch067 on Mar 5, 2018 9:44:12 GMT -5
Stage-2 (220 grit SiC) usually only takes me 1-2 weeks. The scratch marks of the previous 80 grit stage are pretty easy to see using a 10X magnifier. After that... Stage-3 to the polishing each only take me a week. I have been known to take the polish stage out a second week if not satisfied (for polish stage do not just dump it out... polish can be reused in a tumble. Just pick out a few rocks and check out the shine).
I use Lortone 3A and QT-66/12 rotary tumblers. The motors do not have to be oiled, but you should put a drop of oil on the bushings where the rollers go through the frame... NOT a lot.. just a small drop each week when you have to check out the tumblers anyway (I use 3-in-One oil in a very small squeeze bottle). I purchased some alcohol wipes at the store to clean the rubber part of the rollers if I get some oil on them.
I hope this helps
Glenn
anubis63
Post by anubis63 on Mar 5, 2018 10:53:52 GMT -5
That's kind of what I thought. Thanks for the confirmation and thank you for spending the time to post.
anubis63
Post by anubis63 on Mar 5, 2018 11:28:53 GMT -5
By the way gmitch067, do you know if there's a special way to tumble petrified wood?
Post by grumpybill on Mar 5, 2018 12:06:42 GMT -5
I tumble petrified wood the same way I do agate or jasper.
Post by gmitch067 on Mar 5, 2018 12:16:53 GMT -5
Most of the petrified wood I have tumbled was part of a commercial mix that came with my 3A tumbler, and like grumpybill advised, they should be treated the same as jaspers and agates. Beautiful stones.
nchillbilly
Member since January 2018
Post by nchillbilly on Mar 5, 2018 17:55:17 GMT -5
Not sure what brand of tumbler you're using, but I have a thumler's ar-2 and model b. Both of those have a small hole on top of the motor case, one at the front of the motor, and one at the rear. About once a month I add a drop of 3-in-1 oil into each hole, and oil the shafts/bushings in the frame at the same time.
anubis63
Post by anubis63 on Mar 8, 2018 4:03:00 GMT -5
Not sure what brand of tumbler you're using, but I have a thumler's ar-2 and model b. Both of those have a small hole on top of the motor case, one at the front of the motor, and one at the rear. About once a month I add a drop of 3-in-1 oil into each hole, and oil the shafts/bushings in the frame at the same time. I have 5 dual drum (3 Lb. per drum) Chicago Electric tumblers and need to oil those I suppose. Where should I oil on those machines? Thanks so much.
nchillbilly
Post by nchillbilly on Mar 9, 2018 10:47:04 GMT -5
I can't say on the chicago electric machines. I just don't have any experience with those tumblers. Have you checked online to see if there is any info regarding maintenance on those?
