newton
Member since February 2018
Post by newton on Mar 12, 2018 21:40:54 GMT -5
This 16" Royal was sitting out in the rain at my neighbor's house and he gave it to me when I did some work for him. I am going to spend the least I can to get this thing working. The screw that moves the rock has 13 turns to the inch and I wonder if it should be changed out, since I am going to have to find a way to configure the motors and pulleys anyway. I have two 1/2 hp motors. One of them is a two speed evaporative cooler motor. I am going to build a stand and I hope to build the mounts for my motors off of that. I am starting at the back because that is where I am missing parts and need the most help. I think I can figure out how to configure the motors/pulleys, but I wonder if anybody has some tips or sources for the parts. I want this saw to work very badly. Attachments:
Post by quartz on Mar 12, 2018 23:02:14 GMT -5
I can turn mine around and take a pic. of the back side; that will give you a basis for questions. The feed drive motors are available from Grainger, I'd have to get the P/N. Someone a year or so ago found the same Dayton gear motor cheaper than Grainger, maybe said person will comment here.
Post by quartz on Mar 13, 2018 16:12:40 GMT -5
newton, here's the pic. off the back side of my Royal saw, looks somewhat different than yours. I can provide sketches of pieces if you want, let me know. Feed motor is Grainger P/N 3M098, motor attaches to sheetmetal cover that pivots on pin sticking out from back of saw shell. That 1/2-13 threaded rod is the proper rod for the feed screw,
newton
Post by newton on Mar 14, 2018 11:36:24 GMT -5
Thanks quartz, I now have a direction, and it looks pretty simple compared to what I was thinking would be missing. I will probably have something else to ask later. The shutoff and switches are gone as well.
Post by johnjsgems on Mar 15, 2018 16:17:37 GMT -5
You want it to work badly, or you badly want it to work well?
