mooresean68
Member since February 2018
Post by mooresean68 on Mar 31, 2018 10:44:30 GMT -5
Hi Everyone Any suggestions on tumbling this stone in a 12lb barrel? It's pretty edgy and I'd suspect quite a bit of loss around those edges during stage 1? Thanks -Sean & Rebecca
saxplayer
Member since March 2018
Post by saxplayer on Mar 31, 2018 10:53:07 GMT -5
I'd use a small tile saw and nip off those edges to save a considerable amount of grinding time.
Post by gmitch067 on Mar 31, 2018 10:57:42 GMT -5
Can you give us the size and the type of stone?
I use the QT66/12 with a 12 lb barrel. Running a sharp edged stone (like the one you show) for a 2-4 weeks of 80-grit usually rounds off the sharp edges a little... but keeps the general triangular shape. The amount of wear also is dependent on the hardness of the other stones in the 12 lb load.
Glenn
mooresean68
Post by mooresean68 on Mar 31, 2018 17:49:56 GMT -5
Thanks for the tips! saxplayer, I wish I had the room for a tile saw and other equipment, right now I'm taking up precious space while my wife is being graciously patient with me! Maybe my dream of a garage will build itself after I win the lottery tonight heheh gmitch067 the size is ~ 4x2 probably not a good fit in the 3lb barrel -s
pizzano
Post by pizzano on Mar 31, 2018 18:09:47 GMT -5
Thanks for the tips! saxplayer , I wish I had the room for a tile saw and other equipment, right now I'm taking up precious space while my wife is being graciously patient with me! Maybe my dream of a garage will build itself after I win the lottery tonight heheh gmitch067 the size is ~ 4x2 probably not a good fit in the 3lb barrel -s In the past, I've used my Dremal to cut-off the corners......it's pain staking, so many shallow cuts around & around......but it' works.....and gives you the opportunity to clean-up the other abstracts at the same time.......Dremel's don't take up much space. A wet stone in an open air environment and wear a protective particulate mask makes it safer too....!
Post by gmitch067 on Mar 31, 2018 22:07:20 GMT -5
For a stone that is 4"x 2" ...not good for a 3A rotary tumbler, but it will be good in a 12 lb one... however... for the sake of keeping the other smaller stones from getting banged-up, do not add any more larger stones. Except for that one large one, keep the rest 3/4" to 1 1/4" in size.
Glenn
