eruyanik
Member since March 2018
Post by eruyanik on Apr 5, 2018 12:43:17 GMT -5
Post by rmf on Apr 9, 2018 10:32:55 GMT -5
eruyanik I see you have several rocks listed here (on the forum) and all of them appear to be weathered and well rounded. I know there are reasons to not crack them but on well rounded rocks like these it is frequently difficult to see detail on the rocks due to weathering. A fresh break might make it easier to ID your rocks. However I realize if you are tumbling them this may not be what you want to do.
Post by Tommy on Apr 9, 2018 10:38:38 GMT -5
I can't tell you how many times I've picked up a rock that looks red or some other dark color and after knocking a window in it finding out it's just surface stained.
Post by mohs on Apr 9, 2018 13:11:32 GMT -5
isn't that the truth ! I call it fooled by oxide I picked up a few these river stones in Phoenix before I caught on Sure that not what the posted stones are, probably just thought I post some examples from long ago
eruyanik
Post by eruyanik on Apr 9, 2018 16:25:07 GMT -5
photograpfic examples are very informative above. by the way thanks to you all for the suggestions. you all are true. i don't want to crack these stones, on the other hand sure i can do if it needs.
additional infos obtained from the stone i have here below:
specific gravity: 3,05
white streak
and i could hardly scratch one or two point with a knife blade (mohs 5-6,5)
Post by mohs on Apr 9, 2018 17:00:26 GMT -5
That stone look like it may be dense, fibrous, & tough Don’t put much credence in this But it may be in the jade type family Or it may just be basalt But Certainly isn’t a what not... m stly
Post by Deleted on Apr 9, 2018 17:35:19 GMT -5
My first thought, based upon color, was epidote. With the other info, however, I agree nephrite is a possibility. You might want to grind or saw a flat spot prior to tumble-polishing just to give you a base to do an RI if it turns out to be something highly translucent.
Post by Fossilman on Apr 10, 2018 9:28:25 GMT -5
As said, window it on the end...
eruyanik
Post by eruyanik on Apr 10, 2018 10:14:04 GMT -5
ok guys, i did a bit:) what do you think about it?
eruyanik
Post by eruyanik on Apr 10, 2018 14:11:42 GMT -5
eruyanik I see you have several rocks listed here (on the forum) and all of them appear to be weathered and well rounded. I know there are reasons to not crack them but on well rounded rocks like these it is frequently difficult to see detail on the rocks due to weathering. A fresh break might make it easier to ID your rocks. However I realize if you are tumbling them this may not be what you want to do. i picked up my rocks from sea shores, so the rocks are in general very well weathered or kind of already tumbled i do not use tumbling, i just have a multidrill set and i use handmade sandpaper discs to polish stones. best regards, Ersin
Post by rmf on Apr 10, 2018 18:51:54 GMT -5
I am impressed with patience
eruyanik
Post by eruyanik on Apr 10, 2018 19:23:28 GMT -5
I am impressed with patience it doesn't take any patience. in the video at 1:11, you can see the sandpaper discs i mentioned. i use this kind of discs with dremel in hand. it doesn't take much time to polish.
