braat
Member since December 2016
Post by braat on Apr 17, 2018 16:27:01 GMT -5
I found a pile (5-10 lbs estimated) of somebody's abandoned tumbling project on the side of a road while I was biking. I picked them up because they looked like they would take a shine and they don't look like anything I find around here. I broke them all up except for the 2 on the bottom before I thought to ID them...the 3 pieces on the top are typical of what I busted up. Anybody know what they are? chert/flint/ agate??
Post by Peruano on Apr 17, 2018 20:37:00 GMT -5
You are in Alberta. If you were in New Mexico, I'd say you found a bunch of iron rich jasper. If they were white on the inside and only red on the outside, I'd say you were confusing the jasper with pieces of quartz that had iron oxidized on the outside. Happy tumbling. At the worst you will end up with red or white rocks that shine.
geostrong
Life is like saltation, you have to bounce off of others to become a well-rounded individual
Member since April 2018
ID Help
Apr 25, 2018 14:13:56 GMT -5
Post by geostrong on Apr 25, 2018 14:13:56 GMT -5
I find some of my best stuff this way! While I am no expert on them, these look to be gastroliths. Essentially they are chert and will take a nice polish.
ID Help
Apr 25, 2018 17:41:07 GMT -5
Post by rmf on Apr 25, 2018 17:41:07 GMT -5
braat If you note the top freshly fractured rock it appears to have a somewhat waxy luster. That says to me agate. There is similar agate sparsely distributed in some north GA limestone. If this is found (originally) in Limestone it is probably a sedimentary agate and it may have some chert or jasper mixed in but generally the more waxy the more I lean to agate. It looks like it has been hit hard at some time in the past (lower stones) and has some serious fractures. Not uncommon in sedimentary agates or cherts. If from Alberta you can get fracturing from temperature change as well.
lookatthat
Member since May 2017
ID Help
Apr 27, 2018 18:51:56 GMT -5
Post by lookatthat on Apr 27, 2018 18:51:56 GMT -5
I was thinking gastroliths too. Which are cool. Possibly deposited by a pleisiosaur. Who knows.
