Post by Tommy on Apr 20, 2018 11:09:54 GMT -5
DescriptionLot #4 is for a medium flat rate box stuffed with SMALL pieces of miscellaneous tumbling rough. Size reference photo shown below. Approximate total weight is 20-25 lbs. These pieces of misc. tumbling rough vary from agate to jasper to other materials. I have done my best to sort by approximate hardness and remove any pieces that will probably disappear if tumbled with agates and jaspers. Auction TermsMinimum Bid: $10 Bid Increments: $2 Added Freight: $14 Payment: Paypal only Auction Start: immediately Auction Close: around 7pm PDT, Monday April 30th (when I post "closed") Photos
nchillbilly
Member since January 2018
Post by nchillbilly on Apr 20, 2018 22:25:42 GMT -5
I'll start the bidding on this lot at $26.00
traincrafter
Post by traincrafter on Apr 26, 2018 23:33:58 GMT -5
30.00
nchillbilly
Post by nchillbilly on Apr 27, 2018 17:47:33 GMT -5
$34.00
traincrafter
Post by traincrafter on Apr 28, 2018 8:34:41 GMT -5
$38
nchillbilly
Post by nchillbilly on Apr 28, 2018 9:06:02 GMT -5
It seems as though 3 members plan on splitting all 20 lots between them, so I won,t continue to muddy up the process. Happy tumbling!
Post by woodman on Apr 28, 2018 9:55:45 GMT -5
As i see it, the idea is to raise money to keep the site up and running, bid them up and help the site! check out 13, it has 4 different bidders, have a go at it, it has some good material in it. Have fun!
nchillbilly
Post by nchillbilly on Apr 28, 2018 13:20:36 GMT -5
As i see it, the idea is to raise money to keep the site up and running, bid them up and help the site! check out 13, it has 4 different bidders, have a go at it, it has some good material in it. Have fun! I am well aware of the concept of an auction, and I hope the site raises a ton of money because I really enjoy the forum. My only point was that, even if I could afford every lot on here, I wouldn't run the bid up on all of them out of consideration of the other members. I'm not offended, just know when to fold.
saxplayer
Member since March 2018
Post by saxplayer on Apr 28, 2018 15:35:48 GMT -5
As i see it, the idea is to raise money to keep the site up and running, bid them up and help the site! check out 13, it has 4 different bidders, have a go at it, it has some good material in it. Have fun! I am well aware of the concept of an auction, and I hope the site raises a ton of money because I really enjoy the forum. My only point was that, even if I could afford every lot on here, I wouldn't run the bid up on all of them out of consideration of the other members. I'm not offended, just know when to fold. Gotta agree with you here. I'm totally bidding on several lots to help "raise money" by raising the price a bit. However I'd like to get one of these lots, but it seems the same person or two are bidding on most the lots that are likely to be the most wanted. I see it as a fairness issue - if I win a lot I'm done bidding on the others to give others a chance. Just my $0.02 and it isn't worth that much.
nchillbilly
Post by nchillbilly on Apr 28, 2018 16:26:06 GMT -5
I am well aware of the concept of an auction, and I hope the site raises a ton of money because I really enjoy the forum. My only point was that, even if I could afford every lot on here, I wouldn't run the bid up on all of them out of consideration of the other members. I'm not offended, just know when to fold. Gotta agree with you here. I'm totally bidding on several lots to help "raise money" by raising the price a bit. However I'd like to get one of these lots, but it seems the same person or two are bidding on most the lots that are likely to be the most wanted. I see it as a fairness issue - if I win a lot I'm done bidding on the others to give others a chance. Just my $0.02 and it isn't worth that much. I hope they raise enough to operate for 2 years. I just knew better than to bid on numerous lots because, knowing my luck, I'd win them and not be able to afford them. I bid on the one I most wanted out of the bunch, but I can't afford to go head-to-head with someone bidding on 5 or 6 lots. Chances are, they have more disposable income than I do. Good luck on your bid(s).
pizzano
Member since February 2018
Post by pizzano on Apr 28, 2018 17:10:07 GMT -5
Gotta agree with you here. I'm totally bidding on several lots to help "raise money" by raising the price a bit. However I'd like to get one of these lots, but it seems the same person or two are bidding on most the lots that are likely to be the most wanted. I see it as a fairness issue - if I win a lot I'm done bidding on the others to give others a chance. Just my $0.02 and it isn't worth that much. I hope they raise enough to operate for 2 years. I just knew better than to bid on numerous lots because, knowing my luck, I'd win them and not be able to afford them. I bid on the one I most wanted out of the bunch, but I can't afford to go head-to-head with someone bidding on 5 or 6 lots. Chances are, they have more disposable income than I do. Good luck on your bid(s). Ya....I was tempted (as if I don't have material to work with...lol..)
Just an observation.......I've only been here a few months, so take as a grain of salt.........the last two bid rounds (consolidated and raised) were from folks I've seldom seen post here (I've been on the side lines for quite sometime prior to joining)..........be it members with history......I'm wondering if this annual material bid process (quarterly perhaps) is something a few hang a round for, wait till the last go-arounds, then go " Texas hold'em" knowing that most will fold........?
The process seems to be for a legit cause......and more than likely, helps out the forum budget in some fashion (if the stake holders) are some how vested and the financials are transparent...........At another forum I was associated with, we held quarterly "garage sales".....all the proceeds went into an account that supplemented the monthly forum maintenance fees........we even made money, and actually added a few features to the web-site that pleased the majority of the members.......and made our (admin's) jobs a little less time consuming...(without compensation).....lol
As stated, just an observation........BTW, that forum (web-site) eventually was sold to a larger interested party that continues to publically service (free) the same genre internationally.
saxplayer
Post by saxplayer on Apr 28, 2018 21:49:43 GMT -5
I supposed I will try to win the one lot I want for the price I deem fair and hopefully contribute towards a good cause =)
Happy to donate straight cash to help too =) Like 1/314th of a bitcoin!! haha
Post by Tommy on Apr 30, 2018 20:47:55 GMT -5
15 minute warning!
Post by Tommy on Apr 30, 2018 21:01:17 GMT -5
Auction closed!! Thank you everyone who participated in all of the auctions I will contact everyone who won a box via PM to get your Paypal information for invoicing.
