gilbert
Member since April 2018
Newb
Apr 21, 2018 13:02:28 GMT -5
via mobile
TheRock likes this
Post by gilbert on Apr 21, 2018 13:02:28 GMT -5
Want to say hi to everyone. Just started rock polishing I have some Boley Agate to play with and a thumblers UV 18. Is there anyone who lives in the Muskogee Oklahoma area like to see in person how it’s done?
Newb
Apr 21, 2018 16:04:36 GMT -5
Post by vegasjames on Apr 21, 2018 16:04:36 GMT -5
Not from Oklahoma, but welcome to RTH.
Newb
Apr 21, 2018 16:42:19 GMT -5
Post by Jugglerguy on Apr 21, 2018 16:42:19 GMT -5
Welcome from Michigan. You don’t really need anyone in person to show you how it’s done, you can learn everything here, at least that’s how I did It.
Newb
Apr 21, 2018 17:37:20 GMT -5
Post by gmitch067 on Apr 21, 2018 17:37:20 GMT -5
Welcome gilbert from Northern California! That UV-18 is one sweet vib tumbler! You should be able to put a nice shine on those Agates. If you run into trouble, let us know so we can talk it over and see if the difficulties can be overcome. There are a lot of good people and knowledge floating around the Forum.
nchillbilly
Member since January 2018
Newb
Apr 21, 2018 20:00:01 GMT -5
Post by nchillbilly on Apr 21, 2018 20:00:01 GMT -5
Welcome to the forum from North Carolina. You can find the answers to pretty much all your tumbling questions on here. There are some very talented individuals that post on here, and they are incredibly helpful. One note: you will probably want to get some sort of rotary tumbler to do your first stage grind. Vibe tumblers are great for stages two on up, but not so much for the initial shaping.
Newb
Apr 21, 2018 21:20:22 GMT -5
Post by gmitch067 on Apr 21, 2018 21:20:22 GMT -5
Welcome to the forum from North Carolina. You can find the answers to pretty much all your tumbling questions on here. There are some very talented individuals that post on here, and they are incredibly helpful. One note: you will probably want to get some sort of rotary tumbler to do your first stage grind. Vibe tumblers are great for stages two on up, but not so much for the initial shaping. Some of the Members like the rock's natural looks... only shiny. The UV-18 will do that real nicely... However... From what I have been told the life expectancy of the vibratory bowl suffers because of the sharp edges wearing down the insides. I noticed this happening when I first started and followed advice to coat the inside of the bowl with super glue. That smoothed out the inside scratches, but after repeated uses the glue shredded away. I since replaced the bowl. I now use a rotary tumbler to knock down the sharp edges before shifting to 220 grit in my UV-18. Good learning experience. Glenn
nchillbilly
Post by nchillbilly on Apr 21, 2018 21:30:30 GMT -5
Welcome to the forum from North Carolina. You can find the answers to pretty much all your tumbling questions on here. There are some very talented individuals that post on here, and they are incredibly helpful. One note: you will probably want to get some sort of rotary tumbler to do your first stage grind. Vibe tumblers are great for stages two on up, but not so much for the initial shaping. Some of the Members like the rock's natural looks... only shiny. The UV-18 will do that real nicely... However... From what I have been told the life expectancy of the vibratory bowl suffers because of the sharp edges wearing down the insides. I noticed this happening when I first started and followed advice to coat the inside of the bowl with super glue. That smoothed out the inside scratches, but after repeated uses the glue shredded away. I since replaced the bowl. I now use a rotary tumbler to knock down the sharp edges before shifting to 220 grit in my UV-18. Good learning experience. Glenn My apologies. I wasn't real clear on my advice for using a rotary. My reasoning was just as Glenn said. The coarse grit eats up bowls, and the vibe doesn't really shape the rocks, which isn't a bad thing if that is what you're after. Folks do them both ways, and neither is wrong, just depends on what you're shooting for.
Newb
Apr 22, 2018 0:10:44 GMT -5
Post by Pat on Apr 22, 2018 0:10:44 GMT -5
Not a tumbler, but there are many experts here. Welcome from California!
Newb
Apr 23, 2018 0:17:17 GMT -5
Post by Tommy on Apr 23, 2018 0:17:17 GMT -5
rads
Making clay each day!
Newb
Apr 23, 2018 8:04:58 GMT -5
Post by rads on Apr 23, 2018 8:04:58 GMT -5
Welcome from Michigan!
Newb
May 13, 2018 22:34:07 GMT -5
Post by TheRock on May 13, 2018 22:34:07 GMT -5
To RTH Forum gilbert from ~Duke in SW Michigan
